JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza programming new Key Fob help!!!!
Pages (4): Previous 1 2 3 4
wahidhussain
09-08-2017, 07:57 AM
#31
no mate not with the new one
when i get to the part of putting the new key in it just continues flashing
wahidhussain
09-08-2017, 07:57 AM #31
Andy-R.
09-08-2017, 09:25 AM
#32
Did it come with the battery already in? have you tried taking the battery out for a few hours and then trying to programme it?
[Image: Lf9Nl.jpg]
Andy-R.
09-08-2017, 09:25 AM #32
[Image: Lf9Nl.jpg]
wahidhussain
09-08-2017, 09:57 AM
#33
Andy-R. Did it come with the battery already in? have you tried taking the battery out for a few hours and then trying to programme it?
yes it did come with battery il take it out
and try again tomorrow
thanks
wahid
wahidhussain
09-08-2017, 09:57 AM #33
thanks
wahid
wahidhussain
12-08-2017, 04:50 AM
#34
update
got it to work :w00t:
well i did buy a 2nd tranmitter from ebay from this guy http://shop.ebay.co.uk/pot_of_gold_777/m...ksid=p3686
and it worked first time
thanks to all you guys for your help :thumbup1:
this what i did worked for me on a is200 03 reg
thanks to scudney on loc
TO LOCK CAR
open drivers side door and remove key from ignition switch
insert key to be programmed into ignition switch then remove it
Within 40 seconds
1. Press lock and unlock on the vehicle door control switch at 1 second intervals 5 times
2. Close and reopen drivers door
Within 40 seconds
2. Insert key into ignition switch
3.Switch ignition ON and OFF once to program new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes.
4. Remove key from ignition switch.
System should now lock and unlock car once or twice depending which mode has been selected
Within 40 seconds
1.Simultaneously press and hold key lock and unlock buttons for a maximum of 1.5 seconds.
2.Within 3 seconds press any key button for a minimum of 1 second.
Note:if system locks and unlocks car twice,progranmming procedure has not been completed.Repeat programming procedure
and get the car start
TO PROGRAMME IMMOBILIZER
Insert programmed black key into ignition switch
Within 15 seconds
1. Press and release accelerator pedal 5 times
Within 20 seconds
1. Press and release brake pedal 6 times
2. Remove black key
Within 10 seconds
Insert black key to be programmed into ignition switch
Within 10 seconds
Press and release accelerator pedal once. Immobilizer warning light will flash
After 1 minute Immobilizer warning light will extinquish.
To exit programming mode:remove ignition key and press brake pedal atleast once with 10 seconds or wait 10 seconds
wahidhussain
12-08-2017, 04:50 AM #34
update
TO LOCK CAR
Within 40 seconds
Within 40 seconds
Within 40 seconds
Within 15 seconds
Within 20 seconds
2. Remove black key
Within 10 seconds
Within 10 seconds
Views 464
29-03-2018, 06:50 AM
Last Post by jasons
Views 687
20-03-2018, 10:28 AM
Last Post by jasons
