Pages (139): Previous 1 2 3 4 5 6139 Next
30-06-2017, 12:23 PM
#31
Not a problem mate,
bit poorly with the whining turbo, and using antilag is certainly a no no with it whining.
but once i get the single on it'll be even more awesome.
As for instant boost changing gear;
yeah when you change gear you pretty much do have instant boost cause the turbos still spinning from the last gear.
thats why you have a dump valve, because if you dont when you let off the throttle to change gear the turbo is still spinning, the cold side still sucking air in, but its got nowhere to go cause the throttle is shut. sp it builds up till it only has one way to go - back out the turbo. this causes the turbo to stall cause it needs to spin the other way to let the air out. so obviously thats not good at all for it, and its even worse for the hot side (exhaust side) cause that could then suck exhaust gas back into the engine, that fills up and trys to stall it again.
A dump valve allows the air on the cold side to escape somewhere else rather than back through the turbo. keeping the turbo spinning the right way ready for you to open the throttle again and suck more air in.
hope ive explained that ok.
30-06-2017, 12:23 PM #31
Not a problem mate,
30-06-2017, 01:01 PM
#32
Marsdendean That has explained every 100%. So is the turbo whining because its been driven to hard, or cant the turbo keep up with the preformance side?
cant really keep up.
basically its the bearing thats whining. its just old and knackered.
Thats why when buying a new turbo a ball bearing turbo is highly recommended.
older turbos (and new cheap ones) use journal bearings and a thrust bearing.
basically a journal bearing is just a collor lubricated by a thin layer of oil. with a thrust bearing on the side. It'll be the thrust bearing thats whining on mine i assume.
whereas a ball bearing turbo is more modern better design and quicker spool
30-06-2017, 01:01 PM #32
30-06-2017, 01:12 PM
#33
Steves confident we can be touch 400bhp at the fly with the setup. and if i can sort a couple more things out maybe a little over.
30-06-2017, 01:12 PM #33
gtst-chris
18-07-2017, 05:42 PM
#34
Nice car mate, I bet its a right weapon now. Just a quick question, I saw you going through Lancaster a few weeks ago (it's where I saw the web address for here lol) and I noticed your inner brake lights flash for a few seconds and then stay constant, how did you do it?
gtst-chris
18-07-2017, 05:42 PM #34
18-07-2017, 05:53 PM
#35
Alrite mate,
i used these: http://superlumination.com/7443_7440.htm
about half way down the page, the single circuit flasher units.
Stav
18-07-2017, 05:53 PM #35
Alrite mate,
Stav
gtst-chris
18-07-2017, 06:02 PM
#36
Cheers, I'm guessing I'd need 2 of these units then?
gtst-chris
18-07-2017, 06:02 PM #36
18-07-2017, 06:27 PM
#37
Depends how you wire it.
The middle lights arent meant to be brake lights on the IS (just fog lights as standard), so when i changed them i just tapped off one light and split the feed to both Fogs.
That way i only needed one.
But if your doing it on your normal brake lights then yes you'll need two. and i'd suggest using the single circuit ones over the duals.
Stav
18-07-2017, 06:27 PM #37
Stav
gtst-chris
20-07-2017, 03:35 PM
#38
Ah nuts just realised you can't use the flasher units with filament bulbs
[SIGPIC]http://i76.photobucket.com/albums/j33/shazza1978/GTSTCHRIS.jpg[/SIGPIC]
gtst-chris
20-07-2017, 03:35 PM #38
20-07-2017, 03:41 PM
#39
oh yes, forgot that too, must be LED;s
20-07-2017, 03:41 PM #39
Marcus_1UZ
20-07-2017, 05:12 PM
#40
Very nice mate, can not wait for JAE, so i can have a good look around your car Wink
Marcus_1UZ
20-07-2017, 05:12 PM #40
Views 802
21-02-2025, 07:55 PM
