JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Vibrating noise while driving
Pages (4): Previous 1 2 3 4
buzzard2011
14-07-2019, 03:33 AM
#31
yeah i think it may be so,ive got no play in the bearings,but on the right front with the wheel of when i spin the hub there is noise,would it be best to do both the front bearings?
cheers.
buzzard2011
14-07-2019, 03:33 AM #31
cheers.
14-07-2019, 04:38 AM
#32
Yes, because my other bearing is now making an annoying noise, wish I'd had both of them done!
14-07-2019, 04:38 AM #32
14-07-2019, 04:44 AM
#33
I wouldn't. They don't normally fail together and getting both done at once won't save you any money. It's an expensive job either way (£200 a bearing including labour & VAT)
14-07-2019, 04:44 AM #33
buzzard2011
14-07-2019, 06:05 AM
#34
i will poke around this weekend,just to ellimate tyres and brakes and anything else that could make a rumble,will prob just change the one side,if it is a bearing.
cheers for the replies as well.
buzzard2011
14-07-2019, 06:05 AM #34
buzzard2011
14-07-2019, 01:34 PM
#35
just a thought,could i replace the whole hub assembly easily enough or is it a big job?
i can get hold of a second hand one for 40 notes that has the bearings and everything in,the bearings may be good? and if they are
this would save me around 150 notes if its easy enough to swap over.
what dya think?:blink:
buzzard2011
14-07-2019, 01:34 PM #35
14-07-2019, 01:35 PM
#36
Yes, I did this on my Fiesta, because it's a car I don't care about and am not planning on keeping long term. The problem with that is you don't know how many miles, how many potholes etc the 2nd hand wheel bearing has endured.
Up to you Smile
14-07-2019, 01:35 PM #36
Up to you Smile
buzzard2011
15-07-2019, 12:29 AM
#37
yes true to say its a bit of a gamble but cant afford at the mo to shell out nearly 200 notes geting a new one,skint at the moment.
if the bearing is good ill be happy,if not all ive lost is 40 notes and ill have to save for a new one.
how hard is it to remove the hub assembly?
from what i can see it will be upper arm and lower arm is that right?any pointers to what to look out for please.Blush
buzzard2011
15-07-2019, 12:29 AM #37
buzzard2011
31-07-2019, 02:41 AM
#38
well,good call on the bearing,had no play whatsoever but sounded like train wheels lol.
changed the hub assembly over and i now have my lexus back...no vibration and no noise.
thanks for the help guysSmile
buzzard2011
31-07-2019, 02:41 AM #38
31-07-2019, 09:02 AM
#39
No problem, that's what the OJC is here for.
31-07-2019, 09:02 AM #39
Views 437
24-07-2018, 04:42 AM
Last Post by speedfreek
