JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 1ggte pistons
1ggte pistons
1ggte pistons
Fozzy
28-11-2018, 12:50 PM
#31
I would pop the pins out and do a visual check for wear on them, cant hurt. Bearings wise i guess you can use the 1g-fe standard for the big ends as they are all 44mm
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
28-11-2018, 12:50 PM #31
28-11-2018, 01:06 PM
#32
I have a set or ARP head studs if you fancy as you are upping the power.....
For the cost of the pins I would replace them now saves something going wrong just after the rebuild....
28-11-2018, 01:06 PM #32
28-11-2018, 01:35 PM
#33
I'm interested in a spare set! How much?
Pm me.
28-11-2018, 01:35 PM #33
Pm me.
Jimbob-T-Lex
Moderator
1,674
28-11-2018, 01:38 PM
#34
yeah ok then thanks
Jimbob-T-Lex
28-11-2018, 01:38 PM #34
yeah ok then thanks
LEX11S
29-11-2018, 09:13 AM
#35
jimbob150385 So i can use my crank gd gd
I need new bearings for the pistons if used
shells i need to find
is it worth changing the piston pins then?
new piston rings
Right
yes you will nedd new mains bearings and new big end bearings
the pistion pins take them out and have alook see what there like you could always take it to a engine builders to get them to check
small end shells for them i had to have made toyota dont stock them dont know of anyone else that does?
new piston rings yes you can still get these from toyota
LEX11S
29-11-2018, 09:13 AM #35
new piston rings
Right
Jimbob-T-Lex
Moderator
1,674
29-11-2018, 12:50 PM
#36
Anyone know how i can get part numbers for these??
Jimbob-T-Lex
29-11-2018, 12:50 PM #36
LEX11S
30-11-2018, 09:57 AM
#37
to get the bearing mate its not as simple as just getting them you need the bearing grading sheet and numbers from the block, crank and rods
to get the right ones then you still have to check the oil Clearance’s to make sure there 100% right
I must be quite lucky having the hole set of genuine lexus workshop manuals at home!
LEX11S
30-11-2018, 09:57 AM #37
Jimbob-T-Lex
Moderator
1,674
30-11-2018, 01:20 PM
#38
Just found this so how will i know which ones i need?
numbers from the block easy enough, crank and rods is there a etching on them?
http://www.toyodiy.com/parts/p_E_199907_..._1301.html
Jimbob-T-Lex
30-11-2018, 01:20 PM #38
Jimbob-T-Lex
Moderator
1,674
30-11-2018, 01:21 PM
#39
very gd link by the looks of thing gives all part numbers
http://www.toyodiy.com/parts/g_E_199907_...VKW_1.html
Jimbob-T-Lex
30-11-2018, 01:21 PM #39
Jimbob-T-Lex
Moderator
1,674
07-12-2018, 10:35 AM
#40
Ok so the nxt thing i have got is a engine that has done 25k miles so i need to get that stripped bear i also got a new gasket set aswell so what is it i need to do to get the the big end shell bearing thought these would be the same as the normal 1g-fe ones and i need the the numbers off the block the crank and the rods for the main bearings was it?
Jimbob-T-Lex
07-12-2018, 10:35 AM #40
 7 Guest(s)
 7 Guest(s)
Views 976
23-03-2019, 05:09 AM
Last Post by jameshunter
