JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza 1ggte pistons
1ggte pistons
1ggte pistons
Pages (5): Previous 1 2 3 4 5
LEX11S
20-12-2018, 09:25 AM
#41
you need the numbers from the block they are stamped on the block where the sump is bolted on then there is a set of numbers on the front of the crank where the crank pully bolts on and also the numbers off the rod caps
LEX11S
20-12-2018, 09:25 AM #41
19-01-2019, 10:32 PM
#42
The 1G-GTE pistons and rods are cast, not forged. Having said that, they have still been well-proven at much higher bhp than those of the 1G-FE. I have them in my engine, because of the lower compression ratio (better for turbo setup) and proven reliability.
19-01-2019, 10:32 PM #42
Jimbob-T-Lex
Moderator
1,674
20-01-2019, 01:30 AM
#43
What boost you running with them mate?
Jimbob-T-Lex
20-01-2019, 01:30 AM #43
20-01-2019, 01:39 AM
#44
jimbob150385 What boost you running with them mate?
1.0 bar.
Personally, I've come to think that the whole "maximum amount of boost" thing is a red herring, if viewed on its own. e.g. If you had an unfeasibly tiny turbo running, say, 10.0 bar, then that might put less strain on the engine (i.e. less air being blown through) than a massive turbo running 0.3 bar. i.e. because the boost level is just a measure of the air pressure, and the overall air flow rate is more important.
20-01-2019, 01:39 AM #44
1.0 bar.
LEX11S
20-01-2019, 08:32 AM
#45
Theres a guy in aus that is running a 1ggte at 500 hp with std rods and pistons!!!!!
and yes they are not forged ive had my rods made stronger!
LEX11S
20-01-2019, 08:32 AM #45
20-01-2019, 08:41 AM
#46
LEX11S Theres a guy in aus that is running a 1ggte at 500 hp with std rods and pistons!!!!!
is it sat in the boot of his 1jz powered is200? Big Grin Big Grin Big Grin
20-01-2019, 08:41 AM #46
LEX11S
20-01-2019, 09:34 AM
#47
nope far from it its in a corolla an old rwd one i think
LEX11S
20-01-2019, 09:34 AM #47
21-01-2019, 01:05 AM
#48
Yeah the 1G-GTE can handle quite a lot of power ! Big Grin
21-01-2019, 01:05 AM #48
LEX11S
23-01-2019, 03:56 AM
#49
yeah they can as long as you have done the right mods on the internals with the early ones! late ones not so bad
LEX11S
23-01-2019, 03:56 AM #49
 8 Guest(s)
 8 Guest(s)
Views 979
23-03-2019, 05:09 AM
Last Post by jameshunter
