JapCarForum Cars, Cars, Cars! General Car Maintenance What have you done to your car today?
Pages (131): Previous 151 52 53 54 55131 Next
14-04-2020, 08:08 AM
I think Phils point is that wd40 isn't a penetrating oil. So it won't help free it up.
14-04-2020, 08:08 AM #521
ZAIS200
14-04-2020, 11:58 AM
Sparkystav I think Phils point is that wd40 isn't a penetrating oil. So it won't help free it up.
I know that but it does say "loosens rusty parts and stops squeaking joints" or something along those lines, so i don't see what was so wrong with trying it especially when the bolt and surrounding area was quite rusty. So i don't consider Phil's "criticism" relevant in this case
ZAIS200
14-04-2020, 11:58 AM #522
Mr Reman
14-04-2020, 12:18 PM
Phil01 Four experienced motor mechanics using WD40 as a release agent???
mmmm
It may not have worked, But we've all been in the same position. When you're out of ideas, WD40's a better option that eyeballing the bolt or nut and WILLING it to loosen. Smile
It may not be the best penetrating oil on the market any more, But it's cheap, And available off the shelf from pretty much every vaguely car or DIY related shop out there.
If it's rust that's holding a fastener, I'll usually make a bluetac "Container" around it then fill it with a strong solution of Deox C for a few hours. Then, 9 times out of 10 it comes off without any drama.
If some muppet's glued something on with half a gallon of thread lock, I break out the blowtorch......... But if you can't heat it because of plastic or rubber fittings, You've got to try whatever you can.
Even if the likelihood of success is slim to none, It's better than trying to stare it loose. Smile
Scotty B.
Air filter by K+N, Exhaust by Japspeed, Brakes by Mintex......... And a scuffed rear arch by my sister. Huh
Mr Reman
14-04-2020, 12:18 PM #523
mmmm
Scotty B.
ZAIS200
14-04-2020, 12:25 PM
Any way my membership pack arrived, so spent a few minutes "OJC'ing" my Lexus and have handed out a few membership invites
ZAIS200
14-04-2020, 12:25 PM #524
ZAIS200
14-04-2020, 12:33 PM
Mr Reman It may not have worked, But we've all been in the same position. When you're out of ideas, WD40's a better option that eyeballing the bolt or nut and WILLING it to loosen. Smile
Scotty B.
Couldn't have said it better myself...
Especially when the four experienced mechanics are 2 diesel-macs and one of their apprentices, plus myself who has 1st and second year motor mechanics and 2 year apprenticeship at Ritters toyota in Windhoek Namibia.
ZAIS200
14-04-2020, 12:33 PM #525
Scotty B.
17-04-2020, 12:46 AM
This!
[Image: 391393_10151408066201644_943864218_n.jpg]
[Image: 942814_10151408066111644_1691254934_n.jpg]
Pretty much everything in the first photo was required to change a foglight bulb...
Also did spark plugs on Dan's car. It's always a bad sign when you have a bit of oil on the spark plugs... the plug wells in this case were FULL of oil!
This was the best of the 4, the others were worse.
[Image: IMG_20130528_203206.jpg]
[Image: IMG_20130528_203103.jpg]
There was one I didn't take a photo of where the whole spark plug bit and the 3/8-1/4 adaptor were covered in oil. New rocker cover gasket needed I think!
Edited 29-05-2013, 10:22 AM by toxo.
17-04-2020, 12:46 AM #526
This!
17-04-2020, 12:52 AM
brought a carbon fibre bonnet Big GriniscoStu:
17-04-2020, 12:52 AM #527
Chris0121
17-04-2020, 01:33 AM
is300_dino brought a carbon fibre bonnet Big GriniscoStu:
Awesome mate can't wait to see it on the car will look awesome on the red
Chris0121
17-04-2020, 01:33 AM #528
17-04-2020, 02:41 AM
got to try and get it yet though, its up in bury im in Reading need a van lol
17-04-2020, 02:41 AM #529
17-04-2020, 03:08 AM
Post up on Shiply, it might take a few days but you'll get someone to move it cheaper than a courier.
17-04-2020, 03:08 AM #530
 10 Guest(s)
 10 Guest(s)
Views 926
27-01-2021, 01:37 AM
