JapCarForum Cars, Cars, Cars! General Car Maintenance Inspection done today on my is200
1374lee
26-01-2021, 01:37 PM
Well,my mate who is an MOT tester did a bit of an inspection on my car today,looks good underneath.
All wheel bearings were fine and bottom ball joints seemed good.He did find though that the drivers front caliper is stuck on causing the pads to wear down more than the other side,disc is worn bad aswell due to the excess heat.Got to try and release the caliper now,if not then a new caliper it will have to be.
New front discs and pads now also required.
Thanks.Lee.
1374lee
26-01-2021, 01:37 PM #1
Thanks.Lee.
26-01-2021, 02:15 PM
If you can release the caliper just need slide pins will have it like new, common fault on these cars.
26-01-2021, 02:15 PM #2
1374lee
26-01-2021, 03:11 PM
Sparkystav If you can release the caliper just need slide pins will have it like new, common fault on these cars.
Yes I seen the guide on LOC about the pins and dust seals,best get them and do both front calipers I think,even though only the driver side has the problem right now.Is it worth getting a caliper refurb kit of seals etc?
Thanks.Lee.
1374lee
26-01-2021, 03:11 PM #3
Thanks.Lee.
27-01-2021, 01:37 AM
whilst youve got it apart it cant hurt!
27-01-2021, 01:37 AM #4
Replies 1,307
Views 61,027
01-02-2024, 03:16 AM
Views 343
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 703
28-06-2022, 04:42 AM
Last Post by MichaelTTE
Views 967
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,484
22-07-2021, 03:46 AM
Last Post by simon87
Views 597
17-03-2021, 09:57 AM
Last Post by iceman
Views 939
17-02-2021, 08:43 AM
Views 829
11-02-2021, 11:27 AM
Views 868
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 1,046
27-01-2021, 04:28 PM
