JapCarForum Cars, Cars, Cars! General Car Maintenance IS200 wont run
IS200 wont run
IS200 wont run
MichaelTTE
28-06-2022, 04:42 AM
Hi All,
Back again with a little issue, I,m wondering if anybody has experience or suggestions please.
I have a IS200, not used daily, I went t start it last weekend and it wouldn't run. It cranks and fires - but only for a second or so then cuts out. After four or five attempts the battery fell away (not cranking), so I jumped it off another car. After a few more attempts it struggled into life, it idled for a minute and the revs dropped and cut out. Jumped again, it ran ok if I kept the revs up but dies off when idling. No warning lights on and no fault codes displayed (with the OBD reader I have). This morning I replaced the battery, still runs for a second and cuts out. I have checked all connector plugs earth straps (put the jump lead from the battery neg to the engine!) fuel in the tank, and a smell of fuel after a few attempts vacuum hoses etc, fault persists.
The one thing I have noticed is that with the ignition on, there is a buzz coming from the throttle control area. I don't recall that this is normal - can anybody confirm / deny?
As the engine runs ok once it has started, I'm discounting the spark side of things, so it should be a air or fuel related. Throttle position doesn't have any effect, and I can see throttle opening and closing on the OBD.
For what its worth I put up a video here - the engine sounds rough as the cover is off the air filter https://youtu.be/LmpR8k46z6I
Thanks for any help!
MichaelTTE
28-06-2022, 04:42 AM #1
Hi All,
Views 339
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 963
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,470
22-07-2021, 03:46 AM
Last Post by simon87
Views 592
17-03-2021, 09:57 AM
Last Post by iceman
Views 936
17-02-2021, 08:43 AM
Views 826
11-02-2021, 11:27 AM
Views 862
28-01-2021, 06:18 AM
Last Post by 1374lee
Views 1,042
27-01-2021, 04:28 PM
Views 924
27-01-2021, 01:37 AM
Views 801
19-01-2021, 01:50 PM
