JapCarForum Cars, Cars, Cars! General Car Maintenance New front uprated brakes required is200
1374lee
26-01-2021, 01:34 PM
As above,had a bit of an inspection on my car tody,drivers front brake caliper is sticking on,pads and disc that side are worn down.Anyway I need a good uprated set of discs and pads.Any ideas of what people use.
I know the Brembos seem good,what about pasds though,I am open to ideas but not EBC greenstuff pads.
Finally would you go for grooved or drilled discs or both together.I have my concerns about drilled discs as when they get older the holed tend to crack.Any thoughts on this would be great.
Thanks.Lee.
1374lee
26-01-2021, 01:34 PM #1
Thanks.Lee.
26-01-2021, 04:56 PM
You need to fix the caliper first as its sticking so it wouldnt matter changing the disc and pads it will happen again. But I use grooved and drilled on mine with mintex pads
26-01-2021, 04:56 PM #2
26-01-2021, 11:08 PM
There is a walk through for reconditioning calipers on the site mate Smile it's not to hard to do as it goes Smile
26-01-2021, 11:08 PM #3
rob
27-01-2021, 12:01 AM
1374lee As above,had a bit of an inspection on my car tody,drivers front brake caliper is sticking on,pads and disc that side are worn down.Anyway I need a good uprated set of discs and pads.Any ideas of what people use.
Thanks.Lee.
Why do you need "uprated" discs and pads? Why wont standard aftermRket items do? Unless you want bling factor dots and grooves on "uprated" discs and pads will make **** all difference.
You need to sort out the sticking caliper first, if you are lucky you can free it using rubber grease other wise you are looking at a caliper strip.
I made a photo walk thru a month or 2 back.
Split the caliper- it's so much easier and buy the toyota rubber grease.
rob
27-01-2021, 12:01 AM #4
Thanks.Lee.
27-01-2021, 01:37 AM
Rob he's got the old Turbo IS that belonged to Daz/Dean, id suggest uprated parts could help on his car
27-01-2021, 01:37 AM #5
rob
27-01-2021, 04:28 PM
Given same brakes are on the gs300 its maybe marginal.. more bling factor. In my view anyway . Wink
rob
27-01-2021, 04:28 PM #6
Views 381
09-11-2023, 11:04 AM
Last Post by Keeperlit19
Views 1,225
13-12-2022, 01:41 PM
Last Post by jimxms
Views 743
28-06-2022, 04:42 AM
Last Post by MichaelTTE
Views 886
13-04-2022, 01:27 AM
Views 1,035
08-11-2021, 10:57 AM
Last Post by Morango
Views 1,575
22-07-2021, 03:46 AM
Last Post by simon87
Views 630
17-03-2021, 09:57 AM
Last Post by iceman
Views 1,034
17-02-2021, 08:43 AM
Views 907
11-02-2021, 11:27 AM
Views 936
28-01-2021, 06:18 AM
Last Post by 1374lee
