JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security auto folding mirrors
Pages (9): Previous 14 5 6 7 8 9 Next
25-11-2020, 01:16 PM
#51
1st glanse possible r6 is in the wrong place should be the other side of the potensiometer might not make any difference
(been a while since i built it lol)
25-11-2020, 01:16 PM #51
25-11-2020, 01:23 PM
#52
check the solder joint on d1 looks like it might be joint even though you have cut the track
c3 is the wrong side of transitor (again might not be a problem just going from what i can see)
25-11-2020, 01:23 PM #52
Mr Reman
25-11-2020, 01:25 PM
#53
That shouldn't cause a problem, I've just shuffled the pot to the end of the tracks and moves R6 across so I could get the potentiometer to the end of the board. Same with C3, It on the same pair of tracks, Just on a different part of it.
It's totally stumped me because I'm sure the circuit diagram for this would be identical to the original.
Scotty B.
Edited 06-01-2013, 05:18 PM by Mr Reman.
Air filter by K+N, Exhaust by Japspeed, Brakes by Mintex......... And a scuffed rear arch by my sister. Huh
Mr Reman
25-11-2020, 01:25 PM #53
Scotty B.
25-11-2020, 01:35 PM
#54
is the potentiometer on the right pin leg of the IC ? should it not be on next one up
and
the link is on the wrong pin i think
25-11-2020, 01:35 PM #54
and
Mr Reman
25-11-2020, 01:38 PM
#55
I've just double checked the break between the terminals of D1, All the tracks been removed.
I just looked at the diagram again, The transistors ARE the right way around, Aren't they? If you follow the permanent positive along it looks like it goes into the lower of TR1's pins first. Is that right?
Scotty B.
Mr Reman
25-11-2020, 01:38 PM #55
Scotty B.
mattlaw
25-11-2020, 01:43 PM
#56
So is the link right?
mattlaw
25-11-2020, 01:43 PM #56
Mr Reman
25-11-2020, 01:51 PM
#57
The pot has 3 legs. You choose one of the outer ones depending if you want the resistance to go up when you turn it clockwise or anticlockwise. I tested this with a multimeter before fitting it.
I'm using the top two pins (When looked at in the middle picture). The track to the bottom pin is cut and I added a link wire to bring the output of the pot to the track with the second pin down on the right of the 555 chip. The track on the other side of this link is also cut to keep the little section with the pot on it separate from the rest of the board.
As I said, It's likely to be something blindingly obvious........ Though it could also be I something as difficult to diagnose as a dud component. Huh
Scotty B.
Mr Reman
25-11-2020, 01:51 PM #57
Scotty B.
25-11-2020, 01:58 PM
#58
then it all looks fine mate could be the capacitor is to big lol
25-11-2020, 01:58 PM #58
mattlaw
25-11-2020, 02:02 PM
#59
Andy - make me 1 pretty please
mattlaw
25-11-2020, 02:02 PM #59
Mr Reman
25-11-2020, 02:16 PM
#60
Rabster then it all looks fine mate could be the capacitor is to big lol
C1, 2 and 4 are rated to 50v.
C3 and C5 are 35V.
I tried to get them all at 35v, But Maplin doesn't keep much of a stock when it comes to capacitors. :blink:
Scotty B.
Mr Reman
25-11-2020, 02:16 PM #60
C3 and C5 are 35V.
Scotty B.
Views 1,392
26-12-2019, 01:39 PM
Views 1,570
21-04-2019, 10:20 PM
Last Post by aaronabbott
