JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Auto box + Aftermarket ECU?
26-12-2019, 04:36 AM
I promise I'll stop banging on about gearboxes eventually, I've just had a brainwave....
How much of a problem is it to use an after-market ECU when you have an electronically controlled auto gearbox? Specifically, I'm thinking of the 6 speed shiftronic from a late spec LS430.
Will I have to keep the 3uzfe ecu to run the gearbox? That's going to mean having the is200 ECU, LS430 ECU and a link ECU running side by side, which obviously I'd like to avoid.
26-12-2019, 04:36 AM #1
26-12-2019, 07:23 AM
I don't think the link will do it without some very creative wiring and a waste of outputs lol
Why the auto box?
26-12-2019, 07:23 AM #2
Why the auto box?
26-12-2019, 07:25 AM
Ps have you seen this:
Lexus 1UZ-FE to Audi 012 ( 01E / 01X ) / Porsche G86 Adapter plate
eBay item; 120855489671
26-12-2019, 07:25 AM #3
26-12-2019, 10:08 AM
Sparkystav I don't think the link will do it without some very creative wiring and a waste of outputs lol
Why the auto box?
I'm just considering all the options. If I'm going manual, I'm probably going to source a T56. Not had a look at audi boxes though, will have to have a look at the ratios.
The reason I was looking at this autobox in particular is because it's got a sequential manual mode, so I wouldn't lose the driving experience. I think it is going to be A LOT cheaper to get that in the car than converting the 1uz to a manual.
Only other consideration is the extra 30kg + that the autobox weighs over the manual.
I'll check the ebay link out when I get home, it's blocked at work. Thanks Stav! The audi/porche transmission seems to be a borg-warner anyway, so it looks very similar to a T56.
Edited 06-02-2012, 01:57 PM by el_bandido.
26-12-2019, 10:08 AM #4
Why the auto box?
26-12-2019, 01:39 PM
Edit: Right, apparently it doesn't have an external TCM, so I'll need the 3uz-fe ECU to run it correctly.
Edited 07-02-2012, 10:10 AM by el_bandido.
26-12-2019, 01:39 PM #5
Replies 84
Views 10,095
17-12-2020, 04:46 PM
Last Post by mattlaw
Views 1,644
21-04-2019, 10:20 PM
Last Post by aaronabbott
Views 1,366
20-04-2019, 05:11 AM
Views 2,481
22-11-2018, 08:22 PM
Views 2,666
27-04-2018, 04:32 PM
Last Post by garyskisplym
Views 2,931
22-01-2018, 07:17 AM
