JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security IS200 Aftermarket headunit HELP!
lexluger
22-11-2017, 09:44 AM
Hi all, can anybody help...
ive just replaced the standard broken headunit in my 2001 is200 sport with a single din pioneer unit. Everything went to plan, amp by pass lead fitted, facia fitted, stereo powers up but no sound?? is there anything im missing? ive double checked all the connections & have ran out of ideas!
Can anybody help or point me in the right direction!
Thanks in advance ppl
lexluger
22-11-2017, 09:44 AM #1
22-11-2017, 10:06 AM
Hmm seems an odd one! have you connected both plug on the back of the stereo? as one is for power etc one is for speakers.
Also is there a setting for "pre-amp" on/off? On my alpine one if your running everything through amps you can turn the normal speaker connections off. thats not happened has it?
22-11-2017, 10:06 AM #2
22-11-2017, 10:13 AM
as above all connections pressed home at the amp end and at the headunit what model headunit is it ?
Rabs
22-11-2017, 10:13 AM #3
Rabs
lexluger
22-11-2017, 11:10 AM
Hi, the head unit is a pioneer deh-p7700mp, i have double checked the connections & there all good. the only thing im not sure about is the connections in the pioneer iso lead that connects to the iso end of the bypass cable & to the headunit itself as i previously had the pioneer in a vauxhall which needed the red & yellow wires swapping. i swapped them back red to red yellow to yellow to use in the lexus which works but no sound!
Ive briefly checked the settings on the pioneer H.U but still no sound!
Would it be a possibility that my Ebay bypass lead itself is dodgy?
Thanks for your help..
lexluger
22-11-2017, 11:10 AM #4
22-11-2017, 11:15 AM
It could be but it shoudl just be straight wires so should be pretty simple
22-11-2017, 11:15 AM #5
sounds like it could be the lead then do you ahve a different unit you could try...
can you provide pics of the install points for connections etc what by pass did you get and what year and spec is the car
22-11-2017, 11:15 AM #6
lexluger
22-11-2017, 11:36 AM
ive also tried an older kenwood that directly connects to the radio end of the bypass lead & that does the same thing, powers up but no sound, although i heard a "crackle" come from the rear speakers when i disconnect then re-connected whilst the ignition was on?
the bypass lead is pc2-105-4 & the car is a 51 plate 2001 is200 sport
thanks..
lexluger
22-11-2017, 11:36 AM #7
thanks..
Chri5
22-11-2017, 11:54 AM
If both headunits are notgiving sound then surely that points to the amp bypass.
I'd start there.
Chri5
22-11-2017, 11:54 AM #8
I'd start there.
lexluger
22-11-2017, 12:57 PM
Well so far i can only presume that the amp bypass lead i have is somehow the problem, i noticed there are some looped wires in the big white connector (amp side) of the bypass lead, does this sound right? Does anybody have a pic of their correct lead that i can cross referance with the one i have?
Cheers..
lexluger
22-11-2017, 12:57 PM #9
Cheers..
22-11-2017, 01:01 PM
can you upload a pic of your current bypass lead showing all wires but mark which is pin one somehow ...
22-11-2017, 01:01 PM #10
Views 617
30-09-2022, 11:42 AM
Replies 88
Views 18,886
26-01-2020, 06:18 AM
Last Post by iceman
Views 2,184
30-09-2019, 12:19 PM
Last Post by timmurray85
Views 597
28-09-2019, 08:22 AM
Views 379
17-09-2019, 11:52 AM
Views 663
12-07-2019, 10:36 PM
