JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Help required aristo v300 aftermarket amp fitting
simgoy
20-07-2019, 01:43 PM
Hi all I am trying to fit an aftermarket amp in to my aristo v300 however I can't get it to Work I am trying to use the speaker outs of the stock amp but it won't switch on the new amp and its driving me insane so any help would be greatly received I would like to get this sorted before JAE
simgoy
20-07-2019, 01:43 PM #1
20-07-2019, 01:55 PM
The speaker outs won't switch it on, you need to supply it with a switched 12v.
The speakers you need a line to phono adaptor to change it to RCA plugs to attach the amp input to.
20-07-2019, 01:55 PM #2
simgoy
20-07-2019, 02:06 PM
Sparkystav The speaker outs won't switch it on, you need to supply it with a switched 12v.
I have a switched 12v when you say a line to phono adaptor what do you mean? And where an I get then?
simgoy
20-07-2019, 02:06 PM #3
20-07-2019, 10:18 PM
Which after-market amp are you using?
Some have input sensitivity to turn on when they sense a signal coming in via the audio inputs. I have an amp that does that.
However they have a reputation for draining battery's as the input sensitivity can be to high and even a tiny voltage (induction voltage from a different circuit even) can leave an amp on overnight with obvious consequences.
20-07-2019, 10:18 PM #4
simgoy
20-07-2019, 11:38 PM
Mate it's a vibe slik a1 amp
simgoy
20-07-2019, 11:38 PM #5
23-07-2019, 05:42 AM
You will defiantly need a remote turn on as Stav has said. If your HU doesn't have one, locate a switched live somewhere else and use that instead. You don't need phono adaptors just use the High input connections and let the amp do the work.
23-07-2019, 05:42 AM #6
Views 788
31-03-2020, 12:49 PM
Replies 88
Views 19,637
26-01-2020, 06:18 AM
Last Post by iceman
Views 330
04-09-2019, 11:50 PM
Views 566
24-06-2019, 08:10 AM
Last Post by jomo
Views 909
29-04-2019, 07:48 AM
Views 811
26-12-2018, 07:50 AM
Views 394
06-11-2018, 01:05 PM
Last Post by yellowbob
Replies 37
Views 2,304
14-05-2018, 09:34 AM
Last Post by jimxms
Views 601
04-05-2018, 12:42 PM
