JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Aftermarket Headunit - Fitting
Pages (3): 1 2 3 Next
18-01-2018, 09:43 AM
Right, im planning to instal mu HU soon, hopefully this weekend, and just want to know a few things to make the install as quick as possible.
1. The headunit i have has the external brain, im thinking i want to put this in the boot, if the cable is long enough. What side of the car can i get the cables through to the boot? Dont really want it under the seat, however i have the ipod connecter and again need to check how long the cable is.
2. What would be the best route to run the cables, down the passenger side or through the centre?
3. Have most used the brackets that come with the facia adaptor to fix the unit?
Plus any hints or tips would be great:thumbup1:
Cheers
18-01-2018, 09:43 AM #1
Cheers
18-01-2018, 09:54 AM
I run electrics down the N/S and sound on the other side. However a few people on this site run RCA's and speakers straight down the middle, shorter cables and really easy to do also.
There is a hole behind the rear seat into the boot area on the top right hand side, plenty of room.
18-01-2018, 09:54 AM #2
18-01-2018, 09:58 AM
2tongues There is a hole behind the rear seat into the boot area on the top right hand side, plenty of room.
When you say right, do you mean looking at it from the boot or in the car?
18-01-2018, 09:58 AM #3
18-01-2018, 09:59 AM
TBH I think its on both sides?? but I was meaning the filler cap side.
18-01-2018, 09:59 AM #4
18-01-2018, 10:02 AM
There's definitely a hole on the right hand side of the boot (that's the drivers side) as that's where wozza and I ran the cable through for my nav voice recognition.
18-01-2018, 10:02 AM #5
18-01-2018, 10:03 AM
That will be both sides then!!
18-01-2018, 10:03 AM #6
18-01-2018, 10:06 AM
Cool thanks!
18-01-2018, 10:06 AM #7
Cool thanks!
18-01-2018, 10:50 AM
SHAHZ 3. Have most used the brackets that come with the facia adaptor to fix the unit?
You mean the plastic side pieces, to replace the metal OEM ones, that hold the a/c unit as well as the head unit ? I used those, yes.
18-01-2018, 10:50 AM #8
18-01-2018, 11:00 AM
steviewevie You mean the plastic side pieces, to replace the metal OEM ones, that hold the a/c unit as well as the head unit ? I used those, yes.
Yeap thats what i meant, so are the metal ones removed? i thought the ac panel was fitted to this?...
18-01-2018, 11:00 AM #9
18-01-2018, 11:07 AM
SHAHZ Yeap thats what i meant, so are the metal ones removed? i thought the ac panel was fitted to this?...
I'm struggling to remember all the details now, but I'm pretty sure the new ones have mounting holes for the a/c and you use that instead.
18-01-2018, 11:07 AM #10
Views 911
31-03-2021, 06:38 PM
Replies 88
Views 20,328
25-01-2021, 12:07 PM
Last Post by iceman
Views 798
27-09-2020, 02:11 PM
Views 358
04-09-2020, 05:39 AM
Views 985
28-04-2020, 01:37 PM
Views 865
26-12-2019, 01:39 PM
Views 421
06-11-2019, 06:54 PM
Last Post by yellowbob
Views 662
04-05-2019, 06:31 PM
