Pages (139): Previous 14 5 6 7 8139 Next
14-08-2016, 11:40 PM
#51
Sparkystav Get spoiler Sprayed
Fit spoiler
What spoiler have you got ?
14-08-2016, 11:40 PM #51
Fit spoiler
15-08-2016, 12:54 AM
#52
steviewevie What spoiler have you got ?
I've got one of the little three legged ones Stevie
toxo Oh BTW, antilag in a WRC sense of the word doesn't mess around with timing, it spits fuel into the exhaust side of the turbo so it ignites there, thus still producing gas and spinning the turbine. Knackers your turbo really fast though (obviously, because its trying to set fire to it) so homologation cars have it disabled. The Celica GT4 WRC and Corolla WRC have an antilag manifold with extra pipework on it to feed air to the exhaust manifold for the fuel to burn, but it's blocked off on the road going cars. It's only really any good if you can afford to replace turbos every 1000 miles Smile
HTH
Now thats interesting info!
would love that lol
15-08-2016, 12:54 AM #52
HTH
would love that lol
16-08-2016, 07:14 AM
#53
Just added two more things to the bottom of the list.
It was a bargain, i couldnt resist lol
Quote:Find out cause of Noise
Fit CO2 spray electronics
Make Bottle Bracket
Fit Bottle Bracket
Re run Pipework for CO2
Fit fuse and relayholders
Sort out wiring related to above including running live from battery
Sort out Passenger rear window
Fit mirror movement module
Sort out front speaker amp
Fit laptop
Redo Glove box so boxed off
Fit DVD player
Fit screens
Fit screen splitter
AC Panel Mod
Clay car
Get spoiler Sprayed
Fit spoiler
Make AC panel Blue
Rewire front Amp
Fit rev lights
Fit DAB aerial
Fit screws to Speedo surround
Make up FCD
Fit remote and decide on actions
New Power supply for camera
Fit Playstation on board
Fit somewhere to store PS2 Controls (clips on doors?)
Fit new Drop links
Make Front mounted inlet
Fit Adjustable Cam Gears
Speedo Mod
Change EGT gauge lights to blue
Fit EGT gauge and sensor
16-08-2016, 07:14 AM #53
Make Bottle Bracket
Fit Bottle Bracket
Fit laptop
Fit DVD player
Fit screens
Fit screen splitter
AC Panel Mod
Clay car
Get spoiler Sprayed
Fit spoiler
Make AC panel Blue
Rewire front Amp
Fit rev lights
Fit DAB aerial
Make up FCD
Fit new Drop links
Speedo Mod
11-09-2016, 07:28 AM
#54
Right not got far with the list TBH just cant be bothered with the car while its still making an awful noise.
Narrowed it down to the gearbox. so got a replacement today and hopefully be fitted tomorrow. then i should be able to crack on then.
Four more things added regarding single turbo
Make Bottle Bracket Done, just needs spraying
Fit Bottle Bracket
Re run Pipework for CO2 Started
Fit laptop
Fit DVD player
Fit screens
Fit screen splitter
AC Panel Mod Nearly complete
Clay car
Get spoiler Sprayed
Fit spoiler
Make AC panel Blue
Rewire front Amp
Fit rev lights
Fit DAB aerial
Make up FCD
Fit new Drop links
Fit Adjustable Cam Gears Decided to spray them first
Speedo Mod Started
Change EGT gauge lights to blue DONE!
Fit EGT gauge and sensor Sensor fitted, gauge needs a proper mounting
Decide on single Turbo or refurb twins cost dependant
Get single manifold ceramic coated
get adaptor to fit wastegate
Spray cam covers
Anyone fancy paying for my single turbo conversion?
11-09-2016, 07:28 AM #54
Fit Bottle Bracket
Fit laptop
Fit DVD player
Fit screens
Fit screen splitter
Clay car
Get spoiler Sprayed
Fit spoiler
Make AC panel Blue
Rewire front Amp
Fit rev lights
Fit DAB aerial
Make up FCD
Fit new Drop links
Speedo Mod Started
Spray cam covers
11-09-2016, 07:33 AM
#55
:laugh: now thats fund raising at its best.
11-09-2016, 07:33 AM #55
11-09-2016, 11:06 AM
#56
Go for the ceramic coated manifold mate. If possible inner and outer. it is a good mod. I will do the same on mine soon
11-09-2016, 11:06 AM #56
18-09-2016, 10:38 AM
#57
As you may see from my list i had "find out cause of noise"
well basically id had a hollow grinding rotating noise for about 2 and a half months.
It was awful noise and so loud from 40mph upwards! me and my mate hated on the way to JAE but i had to be there!
Anyway i thought the noise was related to the turbos but when i changed then the noise was still there at exactly the same place.
Next idea was to change the dual mass flywheel. i changed it for a single mass one from a 1GGTE and the clutch,
the noise was still there!
so next i changed the gearbox for another, still there!
i was so annoyed and baffled. but the only thing left was the diff.
So last night i started taking the diff off, and after borrowing a couple of tools from work today to finish the job i got it off and took it apart.
This is what i found:
[Image: DSC00373.jpg]
[Image: DSC00374.jpg]
jammed in here:
[Image: Capture.jpg]
Not sure where it came from yet but its def the cause of the problem!
unfortunately its also chipped the final drive gear, dont know if you can see in this pic, but the vanes are chipped:
[Image: DSC00375.jpg]
Just need to figure out where the thing came from, get a new final drive gear and the problem should be sorted!
(the LSD and normal dif have the same one so should be hard to get one from a scrappy)
Also heres a pic of the LSD bit:
[Image: DSC00376.jpg]
gonna fit new front drop links and maybe my adjustable cams while ive got it all up on axle stands at the mo,
On the down side, found a screw in my rear wheel so got to see if that can be repaired tomorrow as well.
18-09-2016, 10:38 AM #57
jammed in here:
18-09-2016, 10:42 AM
#58
Well done for finally tracking that down, must be a relief ! But what on earth is that ? Surely it must have come off somewhere else in the diff ? Would you just be better off fitting a whole new diff ? :confused1:
18-09-2016, 10:42 AM #58
18-09-2016, 10:45 AM
#59
steviewevie Well done for finally tracking that down, must be a relief ! But what on earth is that ? Surely it must have come off somewhere else in the diff ? Would you just be better off fitting a whole new diff ? :confused1:
No not really, cause i have the LSD, their not easy to find, and the LSD bit is fine so just swap bits about,
Think it may have come off the plug maybe. trying to find a thread of Ormi;s now for pics.
18-09-2016, 10:45 AM #59
18-09-2016, 10:49 AM
#60
Found Ormis thread on the other side.
Heres what it is:
[Image: p0108091017.jpg]
My plugs not that long!
so its fallen off the drain plug!!!!
18-09-2016, 10:49 AM #60
Heres what it is:
Views 354
22-02-2024, 02:07 PM
