JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications DIY Supercharger Issue
Pages (10): Previous 14 5 6 7 810 Next
12-08-2019, 12:14 PM
#51
It is easier to just feed a constant 12v to the clutch than try to remove the clutch and bolt it all together. Though having it switchable is an idea I find kinda cool, as would my neighbours, when I get home late at night!
The best solution to the fuel cut problem is to use a "black box" as supplied with the kit by TTE. These are however impossible to find, and so many people use an HKS FCD, it's not an ideal solution, but it will work. Patrick (P.Lindblom, posting above) is making some Black Boxes, I believe, that a couple of members are now running. See details here: http://www.outlawjapclub.co.uk/forum/sho...php?t=8032 and contact him for more info.
12-08-2019, 12:14 PM #51
Jimbob-T-Lex
Moderator
1,674
12-08-2019, 01:14 PM
#52
not sure whether to fit the greddy mate my main concerns like you say is the fabrication of the charger mount ive now got a supra tensioner on its way lol
Jimbob-T-Lex
12-08-2019, 01:14 PM #52
buzzard2011
12-08-2019, 06:50 PM
#53
just a note on a the switchable charger..would it not cause havoc with air/fuelling when turning on and off? would Patrick's black box or the hks fcd be able to cope?
thanks.
buzzard2011
12-08-2019, 06:50 PM #53
thanks.
12-08-2019, 08:21 PM
#54
IIRC the great thing about the blackbox is that unlike the HKS FCD, it only starts changing the reading after a certain point up the scale i.e. when your boosting. The rest of the time it just leaves it alone. Whereas the HKS FCD gives a false reading all the time, regardless of whether or not it's actually required.
So assuming I've got that right, the blacboxes that Patrick makes would be perfect for a switchable charger setup.
I'd been having a think about it myself, and if you want to do it really fancy...get a spare heated seat button (the ones that push in and stay on) and mount it vertically in one of the switch housings to the right of the steering wheel. Then just wire up the positive feed to the electronic clutch to that switch. Maybe even make a little logo that says 'SC' to go over the heated seat icon?
One thing to bear in mind is that it will probably be necesarry to depress the clutch and let the revs drop to idle before engaging the charger as the sudden added resistance of the charger would probably snap the belt after a while.
12-08-2019, 08:21 PM #54
Talisker
12-08-2019, 09:42 PM
#55
buzzard2011 just a note on a the switchable charger..would it not cause havoc with air/fuelling when turning on and off? would Patrick's black box or the hks fcd be able to cope?
thanks.
I've reinstated the clutch on my charger to help with mpg and to give the illusion of a stock IS until I give it the beans :biggrin:.
I've had all three piggyback ecu's on my setup. TTE blackbox (until it terminally packed in and partially melted), the HKS FCD and the Greddy BCC.
All three coped with the clutch element without error. All that happens when the clutch engages is a small jump in boost pressure (maybe 0.075bar), a bit more noise, and a big grin on your face.
Talisker
12-08-2019, 09:42 PM #55
thanks.
reganlives
13-08-2019, 08:04 AM
#56
just read this whole thread and all i have to say is i'm amazed! Its been an idea thats been floating about in my head for a while now to try and do a custom charger install but from seeing what people say it may cost put me off but now i'm getting very tempted. What would be the total cost to do this taking into account fabrication of the cradle?
reganlives
13-08-2019, 08:04 AM #56
Jimbob-T-Lex
Moderator
1,674
13-08-2019, 08:24 AM
#57
im away till december but im going to look into it and get drawings done and get the cost ill keep posting though if someone does the same b4 me let me know lol think properly doing it still looking £700 - £1000
Jimbob-T-Lex
13-08-2019, 08:24 AM #57
buzzard2011
26-08-2019, 08:25 AM
#58
right lets see if i can work this out.
just finished my diy induction,and yes i know my engine bay looks crappy,but it can stay that way untill i finish the charger fit?
this is the piper-cross viper filter I got cheaply of a mate.
[Image: 6220033104_b00400276e_z.jpg]
i then fitted an old fan i had that was lurking in the tool box.
[Image: 6220019676_83a23068ae_m.jpg]
fitted this inside the silicone tube
[Image: 6219505373_02e3fd4327_m.jpg]
then attached it to the pipe which is 3" stainless I acquired from work
[Image: 6220027928_71181f2f40_m.jpg]
[Image: 6219501785_919a913671_m.jpg]
I put a cold air feed from the bumper grill through to behind the headlight to give a better feed of air.
[Image: 6219510375_22912518c5_m.jpg]
[Image: 6219508575_f31e619158_m.jpg]
all the pipework put together,i had to lengthen the air sensor by a few inches though.
[Image: 6220033104_b00400276e_m.jpg]
[Image: 6219513611_fda3bfabd1_m.jpg]
[Image: 6220024506_19ccd62183_m.jpg]
all done with a bit of fettling, reset the ecu and went for a spin,and must say I was quite surprised how much it improved things,dont think its adds much more bhp,but I get a lot smoother acceleration all through the rev range.from low down to top end,and it gets there a lot quicker too,im impressed.
Edited 07-10-2011, 12:52 PM by Fozzy.
buzzard2011
26-08-2019, 08:25 AM #58
buzzard2011
26-08-2019, 08:26 AM
#59
ahh ****,i knew it wouldnt work......!!
buzzard2011
26-08-2019, 08:26 AM #59
26-08-2019, 08:31 AM
#60
I like the idea. Well done. Looks a good little solution.
buzzard2011 ahh ****,i knew it wouldnt work......!!
You need to have [IMG] tags either side of the image, not just the link. Use the button that looks like a couple of mountains against a yellow sky, paste the image link into the popup box and it should insert the tags for you. I'm sure a mod can correct the above post for you though.
You could even have started a new thread for this, as this seems to have very little relevance to the DIY supercharger which is the topic of this thread.
26-08-2019, 08:31 AM #60
Views 2,557
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,161
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 659
05-04-2024, 07:48 AM
Replies 24
Views 1,983
12-01-2024, 05:42 PM
Views 352
03-01-2024, 07:08 PM
Views 240
28-12-2023, 04:46 AM
Views 601
02-12-2023, 07:46 PM
Views 624
04-11-2023, 11:43 AM
Views 168
30-07-2023, 07:38 PM
