JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning Engine Conversion
Engine Conversion
Engine Conversion
Pages (9): Previous 14 5 6 7 8 9 Next
RT
01-07-2016, 10:48 PM
#51
Can you break down the costs, instead of just chucking a figure up?
RT
01-07-2016, 10:48 PM #51
RT
01-07-2016, 11:36 PM
#52
OK, due to various PMs etc, and as not to cause rampant panic that there's some noob that can do 2JZ swaps into a IS for peanuts, I've done some semi proper pricing.
2JZ-GTE engine/loom/ECU - £1100
R154 Gearbox (for instance) - £600
Parts, including all custom pipe work - £1300
Slush fund (unforeseen 'just incase money') - £500
Labour (15 days excluding club discount) - £1500
Total = £5000
Those prices are to the max.
Think I'll have to do a sponsored car over winter to prove it huh?
RT
01-07-2016, 11:36 PM #52
Total = £5000
01-07-2016, 11:54 PM
#53
not criticising here Roadside as my knowledge and expertise isn't anywhere near as good as yours but wouldn't using the R154 limit you a little power wise?
01-07-2016, 11:54 PM #53
RT
02-07-2016, 12:12 AM
#54
The yanks run the R154 up to about 700bhp, it's a strong old box, has a few issues with second gear syncros IIRC but easily sorted. It's probably the cheapest option Vs strength.
RT
02-07-2016, 12:12 AM #54
02-07-2016, 12:15 AM
#55
ahh fair enough Roadside Smile like I say not questioning you was just curiousity. Agreed it's a lot cheaper and more viable option than sourcing a V161 which seem to be going for around 2-3k alone thats if you can find one to start with.
02-07-2016, 12:15 AM #55
RT
02-07-2016, 12:56 AM
#56
You could go W58 if not wanting more than BPU, but it is a bit fragile.
Yeah, the V160/161 aint cheap, when you can get one Big Grin
RT
02-07-2016, 12:56 AM #56
02-07-2016, 01:25 AM
#57
yeah the R154 seems to be fairly easy to get hold of, well easier than a 160/161 Smile iirc you get limited by the turbos before the internals let go.
just found a 161 - CLICKY!!!
02-07-2016, 01:25 AM #57
02-07-2016, 02:14 AM
#58
The R154 is getting very hard to get hold of. just ask marcus.
i'm not doubting your personal costs. but i think youve under estimated the price of the engine/ecu and gearbox a little
02-07-2016, 02:14 AM #58
02-07-2016, 02:15 AM
#59
theres a guy whos got 4 6speeds available now on the mkiv supra forum.
02-07-2016, 02:15 AM #59
02-07-2016, 02:16 AM
#60
I assume that pricing is not a re-built engine - just a "known to be good" one?
The ally welding alone on my conversion came to 1K. But every conversion is going to be different.
Your prices sound good but I fear there may be a few surprises that you may need a bit more than £500 slush fund, lets face it a good tubby is the thick end of 1K, mine I believe was £1200 for the spec it is currently running.
02-07-2016, 02:16 AM #60
 7 Guest(s)
 7 Guest(s)
Views 365
31-01-2021, 02:24 AM
Last Post by ozzie b
Views 443
26-11-2017, 06:04 AM
