Pages (139): Previous 167 68 69 70 71139 Next
Mr Rae
09-12-2018, 02:06 PM
Awsome, looking foward to it. Looks as if RSCS is gunna be a good one
SIDEWAYS IS THE ONLY WAY!!!
Nissan 200sx S14A (Project Baby BEL)
http://www.outlawjapclub.co.uk/forum/sho...php?t=9894
Mr Rae
09-12-2018, 02:06 PM #681
09-12-2018, 02:09 PM
My list so far:
Quote:1. Rebuild Engine Head -done
2. Fit Supra rear arches -started
3. Fit Gearbox temp -done
4. Redo gauge holder
5. Wire tuck on arches -done
6. Remove old wiring -done
7. Fit new alarm -started
8. Remove standard ECU -done
9. Flush rear lip
10. Fit water injection kit and tank -started
11. Return fuel line
12. Check bolts on chassis braces -done
13. Recover roof inside
14. Recover roof outside
15. Redo boot in aluminium (Perspex window?)
16. Make Front mounted inlet
17. Stick HUD controls properly
18. Clean speedo surround
19. New gear display -done
20. Fit new water pipe -done
21. Recover rev lights
22. Make AC panel Blue
23. Fit remote and decide on actions
24. Fit new Drop links
25. Fit purge spray
26. Make intercooler backing
27. Fit movement sensor
28. Make new gearstick panel
29. Start speaker mount rear
30. Fit HKS CAMP -sold
31. Do other side of roof -done
32. Finish button on gearstick
33. Sort roll lock
34. De-power lock switch
35. Refit turbo timer
36. Sort Boot button
So 10 jobs down, 3 others started
09-12-2018, 02:09 PM #682
My list so far:
9. Flush rear lip
25. Fit purge spray
33. Sort roll lock
09-12-2018, 03:04 PM
i have an idea for your water bottle sensor.......when you see a puddle on the floor its full
09-12-2018, 03:04 PM #683
09-12-2018, 03:13 PM
Lol but having a sensor is just way more cooler
09-12-2018, 03:13 PM #684
10-12-2018, 01:05 AM
Sparkystav Lol but having a sensor is just way more cooler
Yes and you will also know when to refil it...I was thinking to fit at the same place the bottle of the water injection. I also need to get a level sensor...
10-12-2018, 01:05 AM #685
10-12-2018, 01:08 AM
I've bought a 5l metal tank for the WI. Going to mount it in the boot
Unless you remove the standard water bottle you won't have space where I've mounted that one.
10-12-2018, 01:08 AM #686
10-12-2018, 07:15 AM
Sparkystav I've bought a 5l metal tank for the WI. Going to mount it in the boot
Aha, what about the other side of the bumper? I think there is a good space there to fit the bottle. I also thought the boot, but i have not found a good place to mount the bottle. It will be a good idea if you post some pics of your WI installation to give some ideas.
10-12-2018, 07:15 AM #687
10-12-2018, 07:23 AM
I thought about that but got the alarm siren and if I need to fit a decent sized tank, pump, and other bits they wont all fit.
I'm Going to follow Jims installation, pump under the carpet in the corner and the tank on top fitted nicely in the corner.
Will post some pics another time.
10-12-2018, 07:23 AM #688
10-12-2018, 08:05 AM
Sparkystav I thought about that but got the alarm siren and if I need to fit a decent sized tank, pump, and other bits they wont all fit.
Ok thanks mate!
10-12-2018, 08:05 AM #689
Ok thanks mate!
18-12-2018, 01:24 PM
Few more pics:
Engine bays nearly done, its not perfect but its good enough
[Image: IMG_1494.jpg]
[Image: IMG_1495.jpg]
[Image: IMG_1496.jpg]
Engines nearly built as well, just need to check all the shim spacings before putting the cam covers on.
Also in order to fit the new manifold im having to move the alternator so its not in the way. I had already made the decision to remove Aircon for 2 reasons - save power, and the pipes just mess up the engine bay lol.
So the brackets nearly done just need some thinner aluminium so it lines up perfectly.
def feel like im getting somewhere now.
[Image: IMG_1493.jpg]
[Image: IMG_1498.jpg]
18-12-2018, 01:24 PM #690
Few more pics:
 9 Guest(s)
 9 Guest(s)
Views 283
22-02-2024, 02:07 PM
