JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Viper VX480 Wire colours????
Pages (13): Previous 15 6 7 8 913 Next
01-01-2018, 04:20 PM
#61
Ah you need a 'confirmed locked' signal for your alarm I guess where as I don't. That's what's that about I think
01-01-2018, 04:20 PM #61
Jimbob-T-Lex
Moderator
1,674
01-01-2018, 04:25 PM
#62
oh ok then rabs way it is im off bed early start and ill keep u lot posted on how im getting on!
Jimbob-T-Lex
01-01-2018, 04:25 PM #62
02-01-2018, 12:30 AM
#63
Do the door switch buttons work when the car is off no acc etc as this would have an impact ?
Same goes for when the car is locked as you don't want the buttons live or you could make the car vunerable to thiefs ?
02-01-2018, 12:30 AM #63
02-01-2018, 05:18 AM
#64
Rabster Do the door switch buttons work when the car is off no acc etc as this would have an impact ?
Well connecting to the door switch does lock it, but as you say leaves the buttons operating and doesnt initiate the alarm so onto the next step.
02-01-2018, 05:18 AM #64
02-01-2018, 05:36 AM
#65
what about taking it to the actual drivers door tumbler...
02-01-2018, 05:36 AM #65
02-01-2018, 05:54 AM
#66
Im talking about connecting to the driver door switches.
when you lock with the key fob the unlock button stops working (though the lock still does stranglely)
02-01-2018, 05:54 AM #66
02-01-2018, 05:55 AM
#67
Sparkystav Im talking about connecting to the driver door switches.
how bizare
02-01-2018, 05:55 AM #67
how bizare
Jimbob-T-Lex
Moderator
1,674
02-01-2018, 07:56 AM
#68
hi all got immobiliser working but hooked up the central locking as u described andrew but to no avail i could hear relays switching but no door locking i got to drive back to camp so ill have a go nxt weekend
Jimbob-T-Lex
02-01-2018, 07:56 AM #68
02-01-2018, 08:57 AM
#69
Did you cut the tracks on the existing board in the car ?
Did you connect a wire in replacement of the tracks you cut or removed and test the standard dock lock system ?
02-01-2018, 08:57 AM #69
Jimbob-T-Lex
Moderator
1,674
02-01-2018, 11:46 AM
#70
I broke the tracks and soldered wires on to the tracks and checked continuity and all was ok i then tested for the pulses and connected the wires as u described i could hear relays switching in the aftermarket alarm but no movement of locks. The immobliser part works great i have to push the unlock button on aftermarket fob to start.
Jimbob-T-Lex
02-01-2018, 11:46 AM #70
 20 Guest(s)
 20 Guest(s)
Views 1,886
22-07-2021, 12:01 AM
