JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications DIY Supercharger Issue
Pages (10): Previous 15 6 7 8 9 10 Next
buzzard2011
26-08-2019, 08:47 AM
#61
yeah,cheers stoney.
buzzard2011
26-08-2019, 08:47 AM #61
yeah,cheers stoney.
Fozzy
26-08-2019, 09:08 AM
#62
Sorted the images for you. As Stoney said, just put [img]image link[/img], and you should be good to go
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
26-08-2019, 09:08 AM #62
26-08-2019, 10:10 AM
#63
Pushing the button and engaging the charger while even on full revs won't damage the belt..that's how the merc one works...3.5k boom charger flicks on..your a/c works in the same way..
26-08-2019, 10:10 AM #63
buzzard2011
26-08-2019, 02:06 PM
#64
thanks guys,ill get the hang of it one day,i guess
buzzard2011
26-08-2019, 02:06 PM #64
168
26-08-2019, 03:38 PM
#65
Ok,
I've having a good rad of this thread and to be honest the 2k price for a charger was out of my range, however if it can be done for cica £600 then that's do-able. However, I'm a bit confused with some of the terminology etc.
Could someone else, in simpleton terms whats needed, other than the charger, intercooler and belt! Obviously I'll need the mount for the charger to sit on (think I have a bloke to do this, although would be handy if there was some sort of plans/design already done) but I'm confused regarding which ecu, blow off valve, clutch switches, which intercooler fits etc etc
PLease explain if you can!
northernmonkey
26-08-2019, 03:38 PM #65
Ok,
lex2oos
26-08-2019, 04:21 PM
#66
I have been planing my install a while now. Charger sits on my bedroom floor for almost a year now. got it for 50 pounds, but without pulley and now I am having a hard time finding one...
anyway I gathered some pictures of other user installs, these pictures are not mine and I hope their owners wont mind Wink
you can see +/- what is needed for complete kit. butterfly valve can be replaced with bypass valve or a bov
[Image: post-27376-1242106133.jpg]
[Image: post-27376-1241890973.jpg]
[Image: post-27376-1241890776.jpg]
[Image: post-27376-1241890673.jpg]
[Image: post-27376-1241890576.jpg]
[Image: mycar043.jpg]
[Image: med_gallery_22067_664_172569.jpg]
[Image: kleinP4210004.jpg]
[Image: kleinP4210003.jpg]
[Image: dsc1091fix.jpg]
[Image: DSC_0020.jpg]
[Image: DSC_0019.jpg]
[Image: b8e7z6nva0sxelkks.jpg]
[Image: b8e7w33ccddzd8z8s.jpg]
[Image: b8e7ojba7xddd0oks.jpg]
[Image: b8e7me464du1wcvak.jpg]
lex2oos
26-08-2019, 04:21 PM #66
buzzard2011
26-08-2019, 04:24 PM
#67
ill try if i can mate,if you've got an Eaton m62 off a merc it should already have the clutch,just need to wire it up to a 12v feed somewhere,see Patrick answer early on in this thread. inter-cooler I guess you can get a universal front mounted one,nothing too big or you will loose boost.well that's what some say?
you will need a fuel cut defender hks or other,again Patrick is making some of his own which should be better.search this post.
ive gone for a hks ssqv but will have to do some tinkering with the spring,depending on the boost I get,also a good idea to get a boost gauge as well me thinks.
happy building.Smile
buzzard2011
26-08-2019, 04:24 PM #67
26-08-2019, 05:19 PM
#68
northernmonkey Ok,
Some good info from Buzzard.
For the complete kit you will need:
Eaton M62 charger, if it's from a Merc it will have a clutch and this needs a 12v constant feed for the charger to be always engaged, as in the TTE setup, or you can wire it to a switch if you wish to turn the charger on and off.
Charger cradle, to mount the charger precisely in the right position. Also a pulley for the front of the engine will be needed, and a belt tensioner on the cradle would be useful (and to TTE spec.) Custom fabrication, difficult!
Intercooler, a universal one will do. Bandit or Ormi have them and should be able to give an idea of size. The TTE one is pretty optimal though, and that is quite small. You will also need pipes from charger to cooler and cooler to throttle body, these all need to be custom fabricated and would not be easy or quick to make!
All that the standard ECU needs to run a charger is an HKS FCD, or for very slightly better fuelling, a "Black Box" the only place in the world I know of to get them from is Patrick, a member in Sweden.
That is mostly it. The TTE setup runs a bypass valve opened by a cable but that can be replaced with a BOV if you choose (some people run both!)
Oh, and some kind of induction kit, but if ure making the other bits, that will be easy!
That is about it, I think.
Edited 07-10-2011, 09:05 PM by Stoney.
26-08-2019, 05:19 PM #68
northernmonkey Ok,
168
27-08-2019, 01:49 PM
#69
It would seem I've fallen at the first hurdle!
I have a made who can make anything from metal, but after showing him pictures etc and talking to him, he don't want to get involved. He cited it's too much work, as the bracket needs jigging etc to get it lined up perfectly for the belt. He also reckons your producing two to get one, because of the jigging process.
I do have some other people I can call on, but I seem really put of now! I'm sure the bracket would be about the only thing holding me back, the pulley can be bought easy enough, and the pipework could be virtually done from a universal kit.
Who wants to make me a bracket? lol!
northernmonkey
27-08-2019, 01:49 PM #69
P.Lindblom
27-08-2019, 02:44 PM
#70
northernmonkey It would seem I've fallen at the first hurdle!
I started making a jig for the bracket/cradle a while back, but I didn't have time to finish it before I sold my supercharger kit. If I get hold of another cradle I could probably replicate it. I've got the tools and materials needed. The only thing missing is a complete jig.
Edited 08-10-2011, 06:29 PM by P.Lindblom.
P.Lindblom
27-08-2019, 02:44 PM #70
Views 3,029
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,370
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 779
05-04-2024, 07:48 AM
Replies 24
Views 2,508
12-01-2024, 05:42 PM
Views 502
03-01-2024, 07:08 PM
Views 330
28-12-2023, 04:46 AM
Views 707
02-12-2023, 07:46 PM
Views 732
04-11-2023, 11:43 AM
Views 239
30-07-2023, 07:38 PM
