What have you done to your car today?
Another pass, you'll be out of toffic soon at this rate.
is300_dino what colour have you chosen?
I been real busy :thumbup1:
last week i raised the rear of my Stagea and lowered the front so when loaded its gone from this
To this
and then changed oil and filter, fitted new iridium plugs and de catted it ready for manual boost controller.
then removed a blockage from the cooling system header tank and pipe on the V8 soarer
and got it back on the road for £20 from what was first thought to be a water pump, then changed engine oil and filter. here it is outside a friends place in Surrey all fixed
Then MOTed the Supra, it went straight through no issues at all
Then fitted a tail gate open warning light, heres a little vid of it in action
And changed engine oil and filter and fitted some yummy heat range 7 iridium spark plugs and went back to .8mm gap after playing about with the fuelling and a .6mm gap and after last nights run out to Brands hatch meet im extremely happy with it.
Nextt on the list is ARC intercooler and HKS vpc to fit
At last Soarer De-limited and speedo reads in MPH. Easy job took about 2 hours all in including coffee and chatting to the Mrs etc.
New tyres are flat so can't put them on will have to wait till the weekend when the big brakes get put on.
Removed some heat shielding off the exhaust to stop it rattling.
Tried to get the ciggy lighter to work - not had any luck, needs a replacement one.
Other then that car is in tip to mechanical condition, still needs paint work at the front though.
