JapCarForum Car Manufacturers Toyota New Toyota FT-86 (new Celica ?)
Pages (14): Previous 16 7 8 9 1014 Next
20-09-2018, 04:01 AM
#71
I can guarantee the veil side kit will be hilarious.
20-09-2018, 04:01 AM #71
20-09-2018, 08:13 AM
#72
More info, stolen from another forum:
Quote:Adding to a long line of leaks these past few days, the specification sheet along with a few more brochure shots of the JDM 2012 Toyota FT-86 made their way onto Japanese forums revealing new details on the firm's rear-wheel drive coupe.
Cutting to the chase, the FT-86 measures 4,240mm (166.9-in.) long, 1,775mm wide (69.9-in.), and 1,285mm (50.6-in.) tall, while riding on a 2,570mm (101.2-in.) long wheelbase.
In its home market of Japan, the FT-86 is powered by a Subaru-sourced 2.0-litre flat-four churning out 200-horses at 7,000 rpm and 205Nm (151.2 lb-ft) of peak torque at 6,600 rpm.
In the first trim level, the manual model tips the scales at 1,230kg (2,711 pounds) while the automatic at 1,250kg (2,756 pounds), with both versions returning a combined fuel consumption of 12.4km/lt [~35mpg or 8lt/100km] on the Japanese JC08 driving cycle.
The car comes in two trim levels (High and Low) in Japan. In second trim level, the manual FT-86 weighs 1,210kg (2,668 pounds) and is rated at 13km/lt [36.8mpg or 7.7 lt/100km], while the automatic at 1,230kg (2,711 pounds) and 12.8km/lt [36.2mpg or 7.8lt/100km].
MORE THINGS OF NOTE:
Strut front, double wishbone rear suspension
Base halogens, optional HIDs on base trim, standard HIDs on high trim
top spec has LSD for manual and auto while low spec only has LSD on manual.
Stability control standard
Only 2 speaker audio on base car, 6 Speaker on High
High spec brakes: ventilated discs front and rear.
Low spec brakes: ventilated front, non ventilated rear.
High spec rides on 17" wheels and low spec on 16.
High Spec:
Has "high-quality fabric" (上級ファブリックWink.
Option for leather heated seats with Alcantara inserts.
Steel door sill insert / scuff plate (ステンレス製ドアスカッフプレート)
Interior metallic door handle inserts
Carbon fiber center console trim
Door courtesy light
Knee pad on console
The "Customise Grade" car is interesting (black and white picture):
the "customize grade" bare bones model is 1190 kg !!
Unpainted bumper
16 steelies (says ornament-included, guessing it includes the logo)
plastic steering wheel
NO A/C (only a heater)
Power door locks
Sunvisor (no vanity mirror)
No speakers
the car require premium unleaded gas (無鉛プレミアムWink
the rear seat is one piece and is foldable (一体可動式)
he high spec model comes with a digital speedo and tachometer (デジタルスピードメーター revメーター)
[Image: FT-86-10.jpg]
[Image: FT-86-9.jpg]
[Image: FT-86-8.jpg]
[Image: FT-86-7.jpg]
[Image: FT-86-5.jpg]
[Image: FT-86-4.jpg]
[Image: FT-86-3.jpg]
[Image: FT-86-1.jpg]
20-09-2018, 08:13 AM #72
High Spec:
Door courtesy light
Knee pad on console
Unpainted bumper
Power door locks
No speakers
20-09-2018, 11:33 AM
#73
Is anyone else a bit disappointed with the end result given the earlier concepts? Looks quite tame, in terms of appearance definitely prefer the 370Z........but I suppose this might be a lot cheaper.
20-09-2018, 11:33 AM #73
21-09-2018, 12:59 AM
#74
Some TRD for you sir?
http://www.ft86club.com/forums/attachmen...1320190760
21-09-2018, 12:59 AM #74
longsh07
21-09-2018, 01:32 AM
#75
And here is Subaru's version of it.
http://www.pistonheads.com/news/default....aign=24613
[Image: Subaru_BRZ_3-L.jpg]
[Image: Subaru_BRZ_1-L.jpg]
Not so sure on the front but I still love the look of it.
OJC Twitter and Facebook
longsh07
21-09-2018, 01:32 AM #75
21-09-2018, 01:56 AM
#76
Front end looks like a sodding scirocco!
21-09-2018, 01:56 AM #76
longsh07
21-09-2018, 02:21 AM
#77
That's the idea isn't it? To compete/best the Scirocco?
Not that that should mean it has to look like one.
Edited 02-11-2011, 11:56 AM by longsh07.
longsh07
21-09-2018, 02:21 AM #77
21-09-2018, 04:14 AM
#78
the trd one looks nice, if only it had full carbon fibre body panels
21-09-2018, 04:14 AM #78
21-09-2018, 12:02 PM
#79
toxo Some TRD for you sir?
That does look better, but the problem it has is that (to me anyway) it's fundamentally not a great looking car - so however many bits you add to it still doesn't quite work.
This is probably just me but when I look at this car I just see random bits from other cars rather than seeing this car as a whole - I can see RX-8, 370Z, Z4 coupe - just not a coherent design.
Part of me wonders whether they've made this car deliberately less desirable (compared to the original concepts) because they're planning a more desirable Lexus version..........
21-09-2018, 12:02 PM #79
22-09-2018, 12:58 AM
#80
I'm glad I'm not the only one that had noticed the Z4 influence!
22-09-2018, 12:58 AM #80
 9 Guest(s)
 9 Guest(s)
Views 723
17-10-2020, 04:52 AM
Views 483
29-08-2020, 10:03 AM
Last Post by Tonyb
Views 1,792
15-04-2020, 11:05 AM
Views 1,034
20-02-2020, 04:04 AM
Last Post by Red Dot
Replies 33
Views 2,510
20-12-2019, 11:45 AM
Last Post by paultsport
Views 724
18-09-2019, 12:05 AM
Views 1,117
19-07-2019, 05:19 AM
Views 874
22-05-2019, 01:29 PM
Views 514
15-04-2019, 08:53 AM
Last Post by Chris
