JapCarForum Car Manufacturers Toyota Gen 6 celica advise
Gen 6 celica advise
Gen 6 celica advise
danyboy6
12-04-2019, 10:40 AM
i got import st202 with super struts.im finding it realy hard to find parts like lowerin kit new shocks ect.so wat i am thinkin get uk spec st202 change the legs over swap banna arms figer 8 links ect.i think the uk wish bone would fit but dose any one no if id keep my drive sharfts or would a need to get uk spec sharfts aswell.
danyboy6
12-04-2019, 10:40 AM #1
danyboy6
12-04-2019, 11:18 AM
just found st202 import but no super stuts?
danyboy6
12-04-2019, 11:18 AM #2
dalegt4
12-04-2019, 12:24 PM
some 202's had superstrut some didnt, alot of imports had it but not the same as the st205 i believe, not really looked at the 202.
however mcpherson is a totally different setup to a superstrut, you will need the whole subframe assembly and then swap the whole lot over to convert to the normal setup.
dalegt4
12-04-2019, 12:24 PM #3
daz@likwidart
13-04-2019, 02:46 AM
I have a SS11 on super struts, when I had the figure 8's replaced they said the GT4 running gear was the same. but I never bothered to look into it more, I was going to get the GT4 coilovers but kept it on super struts.
Likwidart 3D Graphics
daz@likwidart
13-04-2019, 02:46 AM #4
dalegt4
13-04-2019, 05:15 AM
ah yes sory, the 202 do im thinking of the gen7 superstrut version, that isnt as has difeent part numbers. Smile
the arms are the same for sure.
But if you go mcpherson remember you need the above to convert from ss
dalegt4
13-04-2019, 05:15 AM #5
danyboy6
13-04-2019, 08:53 AM
well i just put my car side by side a uk 202 an there so much work to change.leg wish bone and driveshafts and steering rack every think so dif.how ever the rear are spot on the same.got these weird coilovers that slide over my shocks to use smaller springs.have to see to beleave.what a st205 gt4 runs on is what ive got on my 202 at the moso a lil coverting an ill be lower new alloys coming.vilside back bumper then spray job all done
danyboy6
13-04-2019, 08:53 AM #6
dalegt4
13-04-2019, 11:49 AM
the front superstrut is the same yes, the spring rates will be alot different as the st205 weighs alot more than a 202, i knwo toyotas own part numbers for the dampers are different too, although KYB supply a universal strut for both.
the arms are the same though
The rear of your import st202 will be the same as the uk model, the gtfour has different rear shocks.
Like i said mate, people have changed the gtfour to a mcpherson setup and it was alot of work
dalegt4
13-04-2019, 11:49 AM #7
Chris
15-04-2019, 08:53 AM
same set up as a GT-Four as i recall
Chris
15-04-2019, 08:53 AM #8
Views 963
20-02-2020, 04:04 AM
Last Post by Red Dot
Replies 33
Views 2,430
20-12-2019, 11:45 AM
Last Post by paultsport
Views 670
18-09-2019, 12:05 AM
Replies 134
Views 7,080
25-05-2019, 09:07 AM
Views 761
16-12-2018, 09:47 AM
Views 1,292
14-07-2018, 07:02 AM
Last Post by jomo
Views 938
11-06-2018, 02:37 AM
Last Post by uncle bob
Views 737
02-01-2018, 11:17 AM
Last Post by CW Racing
Views 1,487
04-04-2017, 11:36 AM
Last Post by Bandit
