Pages (139): Previous 185 86 87 88 89139 Next
31-03-2020, 05:32 PM
Could it be a resistance issue from the re wire wrong gauge cable maybe ?
31-03-2020, 05:32 PM #861
31-03-2020, 05:34 PM
Ooh one thing that might do it interference on the ecu lines I moved my aem fix to inside the car from the bay and the car worked fine but then stopped playing ball had to take it back out again and me it back to the engine bay that cured the problem
Just a thought
31-03-2020, 05:34 PM #862
Just a thought
speedfreek
31-03-2020, 05:35 PM
Mapping issue perhaps?
I had similar issues on my old standalone and tweaks to the map helped massively.
'99 Lexus IS200 SE Navigator
[/SIZE]
(Current project)
speedfreek
31-03-2020, 05:35 PM #863
[/SIZE]
(Current project)
31-03-2020, 05:36 PM
Hmm it's n idea, I did use most of the standard loom to avoid that. And the resistance from the injectors/igniters back to the ecu is less than 1ohm in each case.
31-03-2020, 05:36 PM #864
Just seems odd it was running fine then stopped, hadnt moved anything in the meantime.
31-03-2020, 05:36 PM #865
31-03-2020, 05:37 PM
speedfreek Mapping issue perhaps?
Hadnt change the map at all by then.
31-03-2020, 05:37 PM #866
mattlaw
31-03-2020, 05:38 PM
Are you running a map or maf sensor?
mattlaw
31-03-2020, 05:38 PM #867
31-03-2020, 05:39 PM
Sparkystav Just seems odd it was running fine then stopped, hadnt moved anything in the meantime.
Couldn't a cable have moved to cause the problems and is now hanging against the loom causing a issue
31-03-2020, 05:39 PM #868
31-03-2020, 05:40 PM
mattlaw Are you running a map or maf sensor?
Map sensor built into the link ecu
31-03-2020, 05:40 PM #869
31-03-2020, 05:41 PM
Rabster Couldn't a cable have moved to cause the problems and is now hanging against the loom causing a issue
Hmm maybe, annoyingly the loom is well tucked away but I'll have a look, it's a good idea.
31-03-2020, 05:41 PM #870
Views 364
21-02-2025, 07:55 PM
