Pages (139): Previous 186 87 88 89 90139 Next
31-03-2020, 06:23 PM
just a quick one i missed.you have bypassed the secound oxegen sensor. this one i missed.
31-03-2020, 06:23 PM #871
31-03-2020, 06:24 PM
Removed all oxygen sensors completely.
31-03-2020, 06:24 PM #872
mattlaw
02-04-2020, 04:40 PM
Any look stav? Can you view all your data on a laptop?
mattlaw
02-04-2020, 04:40 PM #873
02-04-2020, 05:56 PM
no luck so far, been out there tonight with the laptop looking at things and still nothing, though doesnt seem quite as bad, seems more predictable now rather than random misfires so im getting there lol
02-04-2020, 05:56 PM #874
Fozzy
03-04-2020, 02:06 PM
Check all earths for coil packs and injectors. I don't know if they all run back into the ecu and it has a main earth on the ecu. Is the ecu body grounded? If not you may need to check resistances between ecu and all coils and injectors, make sure the wiring is equal for all cylinders
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
03-04-2020, 02:06 PM #875
03-04-2020, 03:53 PM
Hurricane Check all earths for coil packs and injectors. I don't know if they all run back into the ecu and it has a main earth on the ecu. Is the ecu body grounded? If not you may need to check resistances between ecu and all coils and injectors, make sure the wiring is equal for all cylinders
Ive checked all the resistances back to the ecu from the injectors and ignitors. As well as back to earth on the ignitors. checked 12v to all injectors and ignitors as well.
all are ok Sad
03-04-2020, 03:53 PM #876
all are ok Sad
Rolex
03-04-2020, 04:15 PM
Can I suggest a Hammer?
Rolex
03-04-2020, 04:15 PM #877
03-04-2020, 04:18 PM
lol ive thought of it but im determined to get there!
03-04-2020, 04:18 PM #878
03-04-2020, 06:27 PM
right well had a lad round tonight to help diagnose a bit more.
when i first started the car it would hunt on idle, i assumed that was just a feature of the new bits and would be mapped out. However talking tonight, that could of been a symptom of the air leaks.
This in turn could of caused the plugs to foul, which knackered the plugs.
tonight we gave the plugs a proper clean with carb cleaner, wire brush, and some heat. It then started better and wasnt as bad but not great.
so im going to get a new set of plugs and with all the leaks fixed it might work.
if not after that i will go insane!
03-04-2020, 06:27 PM #879
lex2oos
04-04-2020, 03:19 AM
myb some of vacuum hoses has gone loose?
lex2oos
04-04-2020, 03:19 AM #880
 9 Guest(s)
 9 Guest(s)
Views 364
21-02-2025, 07:55 PM
