Pages (139): Previous 17 8 9 10 11139 Next
27-09-2016, 01:24 PM
#81
toxo Well, going on a date. Close enough Smile
lol you cleaned the car to pick a lady up!
27-09-2016, 01:24 PM #81
27-09-2016, 01:25 PM
#82
Sparkystav lol you cleaned the car to pick a lady up!
Of course, don't wanna turn up in a shabby looking motor Smile You know what they say about first impressions!!
What's your reason then? Tongue
27-09-2016, 01:25 PM #82
27-09-2016, 01:26 PM
#83
toxo Of course, don't wanna turn up in a shabby looking motor Smile You know what they say about first impressions!!
not telling yet, be patient all will be revealed.
in the mean time should have some more pics of the car tomorrow.
27-09-2016, 01:26 PM #83
28-09-2016, 10:07 AM
#84
Bit more work done today:
Quote:1. Find out cause of Noise DONE!!!
2. Fit CO2 spray electronics Button done, timer not
3. Make Bottle Bracket Done, just needs spraying
4. Fit Bottle Bracket
5. Re run Pipework for CO2 Started
6. Fit fuse and relayholders Done
7. Sort out wiring related to above including running live from battery Done
8. Sort out Passenger rear window
9. Fit mirror movement module
10. Fit laptop
11. Redo Glove box so boxed off
12. Fit DVD player
13. Fit screens
14. Fit screen splitter Done
15. AC Panel Mod Nearly complete
16. Clay car
17. Get spoiler Sprayed
18. Fit spoiler
19. Make AC panel Blue
20. Rewire front Amp DONE
21. Fit rev lights
22. Fit DAB aerial
23. Fit screws to Speedo surround
24. Make up FCD
25. Fit remote and decide on actions
26. New Power supply for camera
27. Fit Playstation on board Started
28. Fit somewhere to store PS2 Controls (clips on doors?)
29. Fit new Drop links
30. Make Front mounted inlet
31. Fit Adjustable Cam Gears Done[/B]
32. Speedo Mod Started, [B]evolved
33. Change EGT gauge lights to blue DONE!
34. Fit EGT gauge and sensor Sensor fitted, gauge needs a proper mounting
35. Decide on single Turbo or refurb twins cost dependant
36. Get single manifold ceramic coated
37. get adaptor to fit wastegate
38. Spray cam covers
39. Give Battery a good trickle charge Done
40. Get tyre put on spare and fitted
Also fitted a thicker wire from the battery to the fuse for my amps.
those that have seen it in the past, i had 4AWG going through the car, but smaller stuff from the battery to the fuse. Not very safe. so a nice new battery connector and 4AWG wire:
Ignore the clips i was charging the battery as well
[Image: DSC00428.jpg]
Also very pleased with myself.
Managed to fit my adjustable cam gears and set the timing up all by myself!
Had them sprayed up in blue to match the car.
these are rare already and i'd bet these are now the only ones in the world.
MMM Rare!!!
[Image: DSC00427.jpg]
28-09-2016, 10:07 AM #84
10. Fit laptop
12. Fit DVD player
13. Fit screens
16. Clay car
18. Fit spoiler
21. Fit rev lights
22. Fit DAB aerial
24. Make up FCD
MMM Rare!!!
28-09-2016, 10:11 AM
#85
Looking good Stav
28-09-2016, 10:11 AM #85
Looking good Stav
28-09-2016, 10:17 AM
#86
Wow, good leap forward for 1 days work!
28-09-2016, 10:17 AM #86
28-09-2016, 10:23 AM
#87
toxo Wow, good leap forward for 1 days work!
been doing work since Saturday, so maybe not as much as i wanted to do,
but plan to do another few jobs this week after work.
28-09-2016, 10:23 AM #87
28-09-2016, 10:41 AM
#88
Marsdendean Looking good stav!
A quick question, could you still keep the twin turbo, but go bigger turbos & would that make it smother rather than having the boost all in one go?
could do, but it'd be the same, all the boost in one go.
and its more difficult to make all the pipework etc.
to have it sequential like the mkiv supra is a right pita cause you need fiddly air valves etc
28-09-2016, 10:41 AM #88
28-09-2016, 11:05 AM
#89
Marsdendean So does your boost from 2 turbos all in one go, rather than using a smaller (or larger ) for boost then the other for top end?
correct their both the same size.
there used to be a useful post on the mkivsupra site on how the ones on them worked, but cant find it.
this may help though: http://mkivsupra.net/vbb/showthread.php?t=27904
28-09-2016, 11:05 AM #89
28-09-2016, 11:14 AM
#90
Looking good there Stav, The more I read you topic the more and more I wish I had that engine. I need to do some more to mine I'm getting a bit fed up with it at the moment so need to do something to get the good vibes back again.
Might say to the boss if she wants a new house I need a new engine :laugh:
28-09-2016, 11:14 AM #90
Views 357
22-02-2024, 02:07 PM
