Pages (139): Previous 193 94 95 96 97139 Next
23-05-2020, 08:20 PM
No idea on power yet, still more to squeeze out once I've measured the cams.
23-05-2020, 08:20 PM #941
Chris0121
23-05-2020, 08:23 PM
We should all have bets on the power output could get interesting lol gutted I never got to hear it at japshow got so many pictures of it on my phone though =)
Chris0121
23-05-2020, 08:23 PM #942
24-05-2020, 03:19 AM
stav you could always have a go at copying this bit of awesomeness, 7" inches of lip in the rear wrapped on a 335/25/19 tire all under the stock body http://www.gowithsolo.com/2008/10/most-i...nt_17.html
so with your arches as they are now you could technically get 14 or 15 inchers in there Confusedhock:
i need to win the lottery
24-05-2020, 03:19 AM #943
01-08-2020, 06:31 PM
I think this thread is well overdue an update with pics :thumbup:
01-08-2020, 06:31 PM #944
01-08-2020, 06:34 PM
well not a lot to update really just a few bits tidiedup in the running for JAE and thats it.
keeping the car together till the Plank and leggit meet then taking it apart again to start the winter jobs.
01-08-2020, 06:34 PM #945
01-08-2020, 06:44 PM
Sparkystav keeping the car together till the Plank and leggit meet then taking it apart again to start the winter jobs.
Feels like you only just put it back together from last winter! lol
01-08-2020, 06:44 PM #946
01-08-2020, 06:55 PM
Lol it did take longer than expected. A finish date April 1st at the latest this time, and not as much work I don't think.
Few more biggish wiring jobs, change of intercooler and piping and a general tidy up.
01-08-2020, 06:55 PM #947
S
02-08-2020, 08:38 AM
Sparkystav ..change of intercooler and piping and a general tidy up.
Same as my plan for winter! Smile
S
02-08-2020, 08:38 AM #948
05-08-2020, 07:48 PM
Well just an update quickly,
Cars taking on the road till the plank and leggit meet then it's project time again!
Heres the list of jobs completed last winter, all the jobs I planned and a few extra!
Quote:Done:
1. Rebuild Engine Head - DONE
5. Wire tuck on arches - DONE
6. Remove old wiring - DONE
8. Remove standard ECU - DONE
10. Fit water injection kit and tank - DONE
11. Return fuel line - DONE
12. Check bolts on chassis braces - DONE
19. Fit new water pipe - DONE
15. Redo boot in aluminium (Perspex window?)
32. Refit turbo timer
7. Fit new alarm
34. Flip flop boot - hole for Allen heads + countersunk
18. Clean speedo surround
35. Extra alarm cable + sensors + run receivers
Cut black green for remote start
Remove brake wire (add intellistart brake wire)
Figure power cable
30. Sort roll lock
33. Boot wire (pop and alarm)
Wiring for engine
3. Fit Gearbox temp
34. Refit battery box - threaded bar platform
29. Finish button on gearstick
36. Solder wires in footwell - radio to find, fit relay or screens.
37. Tape up headlight plugs -done
38. Alternator wire to dash
39. Relay for roll lock and finish wiring to gear stick
40. Run wires for WI - test run, wires to ecu
41. Fog light for dash
42. Figure out buttons for dash - in gauge redo gauge
43. Program dash and ecu
44. Mount thermocouple - under armrest?
45. Pressure pipe from ecu - 6mm fit?
46. Put 5v supply on gauge, earth wire to supply see if works (no supply connection)
47. Rear passenger window fix!
4. Redo gauge holder
48. Mount for exhaust valve
17. Stick HUD controls properly
31. De-power lock switch - works needs depowering - see pic
49. Spacer for exhaust valve
50. Buttons for dash
23. Fit new Drop links - sprayed
Check screen - input2? - done
Fit remote battery port
Fit rear view camera - powered
Box boot off
Alternator bracket
16. Make Front mounted inlet - in progress - done
27. Make new gearstick panel - new RLTC mount and WI LEDs
26. Fit movement sensor - find? - found! - fit - rewire - new one
21. Make AC panel Blue
13. Recover roof inside
28 . Start speaker mount rear - done
2. Fit Supra rear arches
Throttle wire bracket
Fit inlet
Refit gear stick - grease bottom part
Inlet routing
Bottom fuel pipe tighten and seal
Boost controller mount
Tie up cam position wire
Pipes for heater
Inlet control valve
New power steering pipe
Earth strap
Fit WI nozzles
Fuel pipes
Fill with oil
Coolant
Clutch pedal - brake switch - connect wire to RLTC
Remount water tank
Throttle sensor cal
Relay for booster pump and rewire to ecu
Pipes for CO2
Respray engine bay where scratched
reprogram spa gauge
Reprogram ecu
Reprogram RLTC
Test knock sensor
Reprogram dash2 - 6cylinder rpm, move cable so easy when fitted
Gearbox oil
Bleed brakes
Bleed clutch
Power steering fluid
Test throttle input from ecu
Boost pipes - ecu - done, FPR - done, waste gate - done, 2x icv, bov
Get bov welded on
And so I sat down the other day and started my list for winter 2012:
Quote:2012 winter jobs
New intercooler fit
New coil packs
New coil holder
Redo alternator mount
New inlet pipe
Remove abs unit
Remove abs ecu
Power to abs sensors
Move relay and fuse box to boot
Fix high beam
Redo boot strip
Redo gauge holder - LEDs?
Power steering tank to abs place
Swirl pot fit
New pump fit
New feed line
New tank plate
New oil cooler position
Refit power steering pressure sensor to ecu
Knock to ecu
Repipe boost controller
New radiator
New expansion tank
Loosen rear strut adjustment
Measure all struts
Fit ls400 calipers to rear
New discs on rear
Cal boost gauge
Tidy cables behind gauges
Redo brake lines - front to roll control, rear tee'd to cylinder
Fit new oil pump
Rebuild spare engine (need headgasket and arps)
Get new v bands
Fit cam position sensor
Should keep me busy!
Edited 16-09-2012, 11:36 PM by Sparkystav.
05-08-2020, 07:48 PM #949
7. Fit new alarm
Figure power cable
30. Sort roll lock
Wiring for engine
3. Fit Gearbox temp
Box boot off
Alternator bracket
Fit inlet
Inlet routing
Pipes for heater
Inlet control valve
Earth strap
Fit WI nozzles
Fuel pipes
Fill with oil
Coolant
Remount water tank
Throttle sensor cal
Pipes for CO2
reprogram spa gauge
Reprogram ecu
Reprogram RLTC
Test knock sensor
Gearbox oil
Bleed brakes
Bleed clutch
Get bov welded on
New intercooler fit
New coil packs
New coil holder
New inlet pipe
Remove abs unit
Remove abs ecu
Fix high beam
Redo boot strip
Swirl pot fit
New pump fit
New feed line
New tank plate
Knock to ecu
New radiator
New expansion tank
Measure all struts
New discs on rear
Cal boost gauge
Fit new oil pump
Get new v bands
Chris0121
05-08-2020, 08:17 PM
Jesus that's a big list good luck mate
Chris0121
05-08-2020, 08:17 PM #950
 5 Guest(s)
 5 Guest(s)
Views 364
21-02-2025, 07:55 PM
