JapCarForum Car Manufacturers Toyota Mr2 mods and advice
Mr2 mods and advice
Mr2 mods and advice
30-12-2018, 07:04 AM
With you being a carpenter, can't you just build a huge downward slide to get a good run up to the strip on ? .. Stick some sails on the roof, it's always windy at the pod ! Smile
30-12-2018, 07:04 AM #11
30-12-2018, 07:05 AM
All forced induction set ups should have this IMHO.
30-12-2018, 07:05 AM #12
30-12-2018, 07:13 AM
2tongues All forced induction set ups should have this IMHO.
Yeah, water or meth injection are great ways of keeping your engine safe under boost pressure :thumbup1:
30-12-2018, 07:13 AM #13
mr2tubbyben
30-12-2018, 07:23 AM
i don't know a thing about methanol injection..is it just a case of getting the kit, get it properly installed..then headache free motoring? or can it cause issues that otherwise wouldn't have occured?
Id be at max 1.2 bar with the ct20b..is the meth 100% safe? only a few hundred quid..and if it does what it says on the tin, fantastic!
Mr2 rev1 Turbo; decat, mongoose exhaust,blitz induction, gizzmo ms-ibc ebc@1bar, aftermarket intercooler, grooved front discs
mr2tubbyben
30-12-2018, 07:23 AM #14
mr2tubbyben
30-12-2018, 07:25 AM
purplewitch With you being a carpenter, can't you just build a huge downward slide to get a good run up to the strip on ? .. Stick some sails on the roof, it's always windy at the pod ! Smile
Lol hmm..sails could be a good option..but got to hope and pray that the wind is blowing in the right direction..
I'm hoping i can run low 13 seconds, don't know if that's a realistic figure with the mods im planning
mr2tubbyben
30-12-2018, 07:25 AM #15
30-12-2018, 07:28 AM
If it runs out of meth or water and your tuned to the limit and continue driving at the limit then you will have a problem. You would be pretty silly to do that.
30-12-2018, 07:28 AM #16
mr2tubbyben
30-12-2018, 07:30 AM
Oh yeh course, just keep a spare bottle of it in the boot!
mr2tubbyben
30-12-2018, 07:30 AM #17
30-12-2018, 07:36 AM
You don't want to run a ct20b at 1.2 bar unless you like replacing pistons. 1.15 should be the absolute limit and only with GOOD supporting cooling (no eBay intercoolers).
Meth and water injection have bottles you have to refill from time to time but the kits usually have a warning LED to tell you when the level is getting low. So almost fit and forget!
30-12-2018, 07:36 AM #18
30-12-2018, 07:40 AM
Depends how you rely on the meth.
If you run it like Jim ran it on his IS as just an added extra, it helps protect the engine but isn't reliant on it.
If its built into your map like I want mine to be you'll need something to tell you when theres no flow. I've got a snow performance bit of kit that sends a 12v signal to the ecu when it doesn't detect flow (pump break, blockage, or you just run out of water). That will be tied to the map to cut things back if it happens to save the engine.
30-12-2018, 07:40 AM #19
mr2tubbyben
31-12-2018, 03:19 AM
I was looking at the snow kits actually..however i spoke to luke@ pacific works yesterday, he reckons i could spend my money in better ways. He said it can sap power, only really beneficial for highly tuned engines in the hot weather. i dont have a clue about it so i can only go by what others advise
mr2tubbyben
31-12-2018, 03:19 AM #20
 3 Guest(s)
 3 Guest(s)
Views 404
21-02-2019, 08:11 AM
Last Post by Dark Samurai
Views 450
12-01-2018, 08:04 AM
Last Post by Asi
