JapCarForum General Discussions The JCF Lounge Anyone with engineering contacts fancy helping out Stav with some machining?
03-02-2019, 02:00 PM
Following on from Stav's thread HERE
I have done him a full set of drawings for the component he needs to be made.
The ideal scenario is that someone on here has access to, or knows someone with access to a 5 axis milling machine which will be able to machine the component from a solid block of aluminium in 1 go. It's a fairly complex design but if it can be done like this it will mean he can just bolt it straight on with no modifications after the machining.
[Image: 3DwithDims.jpg]
The second option is to use vertical only machining in a 2D format enabling the use of water jet cutting. Although this does limit the amount of material that can be removed, as only the areas of the slots which are shared by both the inlet and outlet side can be cut vertically. And final machining to open up the individual slots will need to be done by hand/another machine.
[Image: 2DwithDims.jpg]
But any of you who have access to milling or water cutting machines or know people who could do it, please just take a minute to read the thread Stav started so you know what we're trying to do, and hopefully the drawings I've posted above should make sense.
My explanation may not have made it totally clear, so if you have any questions please feel free to ask and I'll answer as best I can.
Edited 17-03-2012, 12:49 AM by sprinter2012.
03-02-2019, 02:00 PM #1
03-02-2019, 03:08 PM
I can't thank sprinter enough for the work he's done so far to help.
Just need to get it made now!
03-02-2019, 03:08 PM #2
Fozzy
04-02-2019, 03:44 AM
I've not heard anything back r.e the quote I sent you. I had assumed the lead time was too long, so you couldn't wait. If you still need it I'm still capable of doing it for you
Edited 17-03-2012, 01:19 PM by Fozzy.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
04-02-2019, 03:44 AM #3
04-02-2019, 04:38 AM
What quote mate? I never received anything
04-02-2019, 04:38 AM #4
04-02-2019, 06:10 AM
Hurricane I've not heard anything back r.e the quote I sent you. I had assumed the lead time was too long, so you couldn't wait. If you still need it I'm still capable of doing it for you
Which version can you do? The 2D or 3D one?
04-02-2019, 06:10 AM #5
greeny
08-02-2019, 12:10 PM
some one speak to me at the weekend might be able to get the engineer school to do it
[SIGPIC][/SIGPIC]One chance in life - LIVE it to the full
:drink: :thumbup:
greeny
08-02-2019, 12:10 PM #6
:drink: :thumbup:
Fozzy
08-02-2019, 12:27 PM
Im on it thanks Greeny. Started writing the machine code for the CNC this evening, waiting for the billet to turn up. Should really let Stav know this though!
Fozzy
08-02-2019, 12:27 PM #7
08-02-2019, 02:57 PM
Whoop whoop!
08-02-2019, 02:57 PM #8
Whoop whoop!
jomo
08-02-2019, 03:02 PM
Good new eh stav, you get the beast up and running soon!
jomo
08-02-2019, 03:02 PM #9
Fozzy
08-02-2019, 03:03 PM
Anytime in particular to give you a call tomorrow to discuss things?
Fozzy
08-02-2019, 03:03 PM #10
Views 176
14-06-2020, 12:21 PM
Views 279
25-10-2018, 12:28 AM
Replies 18
Views 1,246
06-02-2018, 04:43 PM
Last Post by D6NGR..
Views 538
26-09-2017, 01:06 AM
Replies 27
Views 1,057
24-07-2017, 06:03 AM
Last Post by Asi
Views 481
13-05-2017, 10:21 AM
Views 396
01-03-2017, 03:01 AM
Replies 55
Views 2,544
16-12-2016, 02:54 PM
Last Post by Marcus_1UZ
Views 326
01-11-2016, 04:11 AM
