JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza FIGS Engineering: Supra Disc Upgrade
Pages (4): 1 2 3 4 Next
Poll: If a group buy was arranged, how many of you would be interested?
You do not have permission to vote in this poll.
Yes
100.00%
Votes 6
No
0%
Votes 0
Total 6 vote(s) 100%
20-04-2019, 02:22 PM
Right guys, time for my next upgrade/mod!
I am in the process of ordering, after having a chat with Mike from FIGS, a set of caliper brackets that will allow me to mount my stock calipers further out, enabling me to run 323mm UK Spec Supra discs instead of the 296mm stock ones.
It really is a no brainer if you're thinking about a brake upgrade for an IS200/IS300/Altezza.
My reasons for going for this upgrade over doing the whole Supra caliper upgrade are as follows.
  • No chopping bits off or removing the dust guard
  • You don't have to remove or bleed the brake lines
  • Useable stopping power is virtually identical to the Supra TT calipers, as the tyres become a limiting factor if you go any higher
  • WAY cheaper to buy and maintain
  • Better modulation/pedal feel while braking
Installation
Intallation is simple on these. It's only two steps more than changing your brake rotors during a normal brake job. (Three if you're adding SS lines when you do it.)
-Once your car is lifted securely with the wheels removed you will unbolt & remove the caliper just like when you're changing pads. *If you're doing brake lines now is the time to do it. *
-Remove pads & pad clips from the caliper bracket. You'll need the pad clips for the new bracket.
-Remove the 2-17mm bolts that hold the bracket & remove bracket.
-Remove stock rotor from hub
-Bend back top & bottom of dust sheild approx. 1/4 inch to clear TT rotor (I left these on as they aid in cooling)
-place Supra rotor on hub & check dust sheild clearance. Once ok procede.
-either remove slide pins from stock caliper bracket & press into new caliper bracket **or** press new slide pins into new caliper bracket (pay attention top & bottom are different)
-install new caliper bracket (pay attention to right & left sides)
-install pad clips & pads
-replace caliper & bleed brakes
-bed pads & enjoy.
And a small quote from a guy who has done his maths...
Quote:The force (torque) is directly proportional to the increase in size (radius.) t = F x R
So since the force is equal (same caliper, same piston cross section) the increase in torque is directly the increase in radius.
So 1" on top of 11.7" is an 8% increase in potential braking force. Add in the metalurgical differences of the alloyed rotors and the improved thermal charateristics and I would throw another 5-10% given my experience with the two peice rotors I am running.
I've already ordered the Supra discs and new front pads, and I've also decided to fit new rubber boots and slide pins while I'm at it.
Also just to note, Mike has done me a good deal on this set, as my intention is that once you guys see what a great upgrade this is, we can then organise a group buy with FIGS.
So just to summarise: Stock IS200 Calipers, Stock IS200 Pads, UK Supra Discs
These are not my pictures, but here are a few I found on an american forum to show the brackets, and how the Supra discs look with OEM 17" wheels fitted...
[Image: P1070960.jpg]
[Image: DSCN0648.jpg]
[Image: DSCN0674.jpg]
[Image: DSCN0693.jpg]
Edited 02-06-2012, 02:34 PM by sprinter2012.
20-04-2019, 02:22 PM #1
Installation
-bed pads & enjoy.
S
20-04-2019, 11:35 PM
Tbh the reason I was looking into brake upgrades wasn't an increase in braking power but just because the standard setup are so poorly designed/a weak point of the car and I'm sick of needing to build calipers and carriers.
I'd still be interested though Smile
S
20-04-2019, 11:35 PM #2
20-04-2019, 11:45 PM
Stix44 Tbh the reason I was looking into brake upgrades wasn't an increase in braking power but just because the standard setup are so poorly designed/a weak point of the car and I'm sick of needing to build calipers and carriers.
Another bonus of this setup is that while improving braking performance in basically every area, when you're not using them to their full potential, the increased rotor diameter means you need less braking force to get the same stopping power. Which = less wear to the pads and discs, so longer maintenance intervals.
20-04-2019, 11:45 PM #3
20-04-2019, 11:46 PM
Bear in mind then, supra calipers are notorious for seizing too
20-04-2019, 11:46 PM #4
20-04-2019, 11:48 PM
purplewitch Bear in mind then, supra calipers are notorious for seizing too
Ooh really? I read a post on the MK4OC not too long ago that basically said if you buy second hand UK calipers now, they almost certainly will need a refurb before you refit them to anything.
20-04-2019, 11:48 PM #5
20-04-2019, 11:53 PM
[COLOR="DarkOrchid"]I don't think they even bother talking about it much anymore, it's a given.. I've gone through stages in the last ten years where one every three months has seized up .. admittedly having two supras, doubles my chances and one that doesn't go far in winter encourages this .. but one of the first things my supra expert mechanic said was 'Your caliper is seized, get used to this'
We even have an almost drive through routine now where I drop in, get it unseized and off I go... don't get me wrong it's not constant - I get one that just does it over and over for a while then it's fine . then another starts [/COLOR]
Edited 01-06-2012, 09:30 AM by purplewitch.
20-04-2019, 11:53 PM #6
20-04-2019, 11:59 PM
I think Supra calipers (along with other big OEM brakes like the 350Z Brembo ones) suffer from what I refer to as 'lazy brake syndrome'
Where the brakes are pretty high performance, but they need a good thrashing on a regular basis to keep them in good working order.
I feel your pain having to unseize yourself that often though Sad
20-04-2019, 11:59 PM #7
S
21-04-2019, 02:15 AM
Sprinter I'm not going to tell you specifics but thank you very much.
I think you might have helped me get a project, that I had given up on, back on track Smile
+rep
S
21-04-2019, 02:15 AM #8
+rep
21-04-2019, 03:34 AM
Why not use LS400 callipers? You can get them to fit the FIGS kit. You will need spacers for standard wheels though.
I still think if you are going to upgrade the brakes you are better off just buying a set of after market 6 or 8 pots. It's a bit more money, but it's money well spent.
21-04-2019, 03:34 AM #9
S
21-04-2019, 03:51 AM
I think you need RCA spacers aswell to fit the LS calipers which pushes the price up.
S
21-04-2019, 03:51 AM #10
Views 281
07-01-2020, 10:49 AM
Views 409
29-07-2019, 09:39 AM
Views 864
17-02-2019, 07:52 AM
Last Post by Jon
Views 386
15-01-2019, 05:15 AM
Last Post by avi_444
Replies 24
Views 2,049
27-05-2018, 11:53 PM
Last Post by Stoney
Views 524
15-02-2018, 02:31 PM
Last Post by LEX11S
Views 733
13-07-2017, 06:09 AM
Last Post by Dan_Turism0
Views 299
14-03-2017, 01:20 AM
Views 702
18-08-2016, 08:29 PM
Last Post by cameron
