JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza hunting on idle and hesitating on part throttle.
S
29-05-2019, 01:54 AM
Hi all,
I'm wondering if anyone can confirm my suspicions and/or give me a solution/their experience of the same problem.
My car has started hunting on idle, not moving off from a standstill unless I give it full throttle and it hesitates at part throttle once moving.
I suspect this is a vacuum or vacuum hose problem.
Does anyone have any ideas? Or is there anything else I should check?
I'm going to remove the TB, give it a clean, change the hoses and see if that sorts it.
Thanks.
Edited 17-07-2012, 04:52 PM by S.
S
29-05-2019, 01:54 AM #1
Hi all,
Thanks.
29-05-2019, 03:01 AM
Yep leaking inlet causes that symptom. So a leaking hose would cause it.
29-05-2019, 03:01 AM #2
S
29-05-2019, 03:15 AM
Excellent, thanks Stav.
S
29-05-2019, 03:15 AM #3
S
06-06-2019, 07:17 AM
Right I've changed all of the vacuum hoses and reset the ECU but I've still got a pending "P0106 - MAP/BARO CKT Range/Performance" Code
so do we think the sensor is buggered?
A friend suggested my E-Manage wiring is causing too much resistance? Is this possible/likely?
Anyone got anymore ideas or suggestions?
S
06-06-2019, 07:17 AM #4
06-06-2019, 08:19 AM
How goods the soldering?
06-06-2019, 08:19 AM #5
S
06-06-2019, 11:23 AM
Erm quite good i'd like to think. but its starting to claw at the back of my mind that its the soldering!
Ill try changing the vacuum sensor and see if that helps then check the soldering, god i hope i dont have to re-do it all!
S
06-06-2019, 11:23 AM #6
06-06-2019, 12:17 PM
Have you tested the resistance from the sensor through the emanage to the ecu?
06-06-2019, 12:17 PM #7
S
06-06-2019, 12:40 PM
No I haven't tested anything for resistance - I know I said I was going to but by the time I'd soldered niegh on every connection 4 or 5 times I was sick!
I'll have to crack out the multi-meter.
On a side note, I don't know what I've done but it boost whistles LOADS on overrun now Big Grin
(It didn't before!)
S
06-06-2019, 12:40 PM #8
(It didn't before!)
06-06-2019, 12:46 PM
What do you mean?
06-06-2019, 12:46 PM #9
What do you mean?
S
06-06-2019, 12:59 PM
I said I was going to test everything for resistance but I couldn't be bothered by the time I had actually finished and it was working (because it had taken so many attempts)
I keep forgetting I'm one of the few Geordies on here!
S
06-06-2019, 12:59 PM #10
Views 159
07-10-2020, 01:46 AM
Last Post by Stoney
Views 223
29-06-2020, 06:21 AM
Last Post by jj260z
Views 223
22-02-2020, 03:31 AM
Views 224
01-01-2020, 08:02 AM
Last Post by jomo
Views 363
23-06-2019, 05:25 AM
Last Post by S
Views 711
26-04-2019, 08:05 PM
Views 391
22-12-2018, 01:54 AM
Last Post by Talisker
Views 498
15-12-2018, 02:54 PM
Last Post by jomo
Replies 23
Views 1,277
08-09-2018, 10:51 AM
Last Post by jimxms
