JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza cleaning throttle body
lex2oos
19-12-2018, 02:42 PM
Hi!
How do you clean yours? do you remove them from engine or just remove the air box? how do you manage not to get any dirt fall in intake manifold?
and why there are water bypass tubes on the TB assembly? do they heat up intake air, or they cool dowh the TB?
thanks Wink
lex2oos
19-12-2018, 02:42 PM #1
Hi!
thanks Wink
Talisker
21-12-2018, 01:12 PM
I've cleaned a couple, on and off the car. It's a bit easier to clean when it's off the car because you can get into all the nooks and crannies that are inaccessible when it's in situ. Taking it off the car also insures that nothing falls in your intake. I use isopropyl alcohol, because it's kinder than a lot of cleaners on the market and perfect for removing the oily deposits in the throttle body.
The water bypass tubes are a function of running the engine in cold conditions. It's supposed to stop the moisture in the induction system freezing as it goes through the TB.
Talisker
21-12-2018, 01:12 PM #2
lex2oos
22-12-2018, 12:53 AM
thanks!
looks like I'm taking off mine
what about the gasket between manifold and TB? can it be reused or it needs to be changed once removed?
lex2oos
22-12-2018, 12:53 AM #3
thanks!
Talisker
22-12-2018, 01:54 AM
I reused mine because it was in good condition, up to you if you want to get a new one. I can't imagine they're that much to buy.
Talisker
22-12-2018, 01:54 AM #4
Views 784
07-06-2019, 02:01 AM
Last Post by S
Views 910
04-04-2019, 01:49 PM
Last Post by spikes
Views 522
06-12-2018, 11:25 PM
Last Post by P.Lindblom
Views 1,037
12-09-2018, 04:29 AM
Last Post by jimxms
Views 2,364
30-08-2018, 02:37 PM
Views 506
27-04-2018, 01:31 AM
Last Post by is300_dino
Replies 61
Views 3,963
17-01-2018, 04:49 AM
Last Post by jimxms
Views 490
10-10-2017, 08:57 AM
Views 261
09-10-2017, 05:41 AM
