JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza reset Throttle Positioning Sensor
09-10-2017, 08:50 AM
ok well this might be what is giving me all the grief after the small problems i had.
any idea's on how to reset it
09-10-2017, 08:50 AM #1
09-10-2017, 09:05 AM
It might seem simple, but have you tried an ECU reset?
09-10-2017, 09:05 AM #2
09-10-2017, 09:08 AM
yes mate. had the battery out for an hour while fixing the short. think this might have messed up the throttle sensor. going to put it on the tester tomorrow
09-10-2017, 09:08 AM #3
10-10-2017, 06:20 AM
Try this - http://bahamutcars.free.fr/workshop/IS_9...i_0037.pdf
10-10-2017, 06:20 AM #4
10-10-2017, 06:39 AM
well found the problem. was a fuse missing. not sure how that happened but all done. fixed the o2 sensor fault and fitted the afr gauge plus fitted new break disks all round. cleared all fault codes and did the needles on my gauge. looks ok but will sand them down and paint them with some glass paint
10-10-2017, 06:39 AM #5
10-10-2017, 08:42 AM
jay_russell well found the problem. was a fuse missing. not sure how that happened but all done. fixed the o2 sensor fault and fitted the afr gauge plus fitted new break disks all round. cleared all fault codes and did the needles on my gauge. looks ok but will sand them down and paint them with some glass paint
Which fuse was missing ?
Great news that you got it sorted :biggrin:
10-10-2017, 08:42 AM #6
10-10-2017, 08:51 AM
it was one in the engine bay fuse box. not sure if i took it out to check it and put it back in the wrong place but thats what was causing all the problems. aswell as a o2 sensor i shopped of ebay that turnerd out to be a fuel air sensor. hence the engine light on. but picked up a old one from work that was working so just changed the plugs over.
10-10-2017, 08:51 AM #7
10-10-2017, 08:57 AM
i have contacted the ebay seller to confirm it's not a o2 sensor and will wait to see what he says
10-10-2017, 08:57 AM #8
Views 3,043
02-11-2022, 10:55 AM
Views 377
23-10-2019, 06:59 AM
Last Post by reganlives
Views 572
12-09-2019, 02:13 PM
Last Post by IanH
Views 786
07-06-2019, 02:01 AM
Last Post by S
Views 346
10-05-2019, 04:47 AM
Last Post by Fry-Up
Views 331
09-05-2019, 12:39 PM
Last Post by jasons
Views 447
22-12-2018, 01:54 AM
Last Post by Talisker
Views 2,364
30-08-2018, 02:37 PM
Views 394
05-07-2018, 12:16 PM
Last Post by Kerja
