JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lambda o2 sensor
Lambda o2 sensor
Lambda o2 sensor
Kerja
05-07-2018, 08:48 AM
Ok, I managed to fit my new japspeed exhaust (its not that loud as I thought it would be tbh) when removing an old one, I had to cut the lambda of, and as a temporary measure I've just insulated the wires and hid it away, there was no check engine or any other faults for two days (even revving it to the red line) however it appeared today.
does this really needs a lambda sensor, or it can be blanked out and somehow reset, or I'd need to buy on of ebay, and just splice it in?
p.s. just in case, its after cat one, on the silencer bit
cheers
Kerja
05-07-2018, 08:48 AM #1
cheers
05-07-2018, 08:51 AM
you will need a bypass speak sparky stav he has the kits and can make you one i think AFAIK
05-07-2018, 08:51 AM #2
05-07-2018, 09:44 AM
you removed the standard sensor after the cat?
yeah i can do you a nice circuit that will fix that!
05-07-2018, 09:44 AM #3
05-07-2018, 11:23 AM
I assume so sounds like the same as I had to do When I fitted a is300 japspeed cat back
05-07-2018, 11:23 AM #4
Kerja
05-07-2018, 12:16 PM
PM'ed
Oh, and I dont see any need of it to be there, as two lamba's in the Catalic converters itself should be more then enough tbh Smile
any opinions on that?
Kerja
05-07-2018, 12:16 PM #5
PM'ed
Views 1,171
02-11-2022, 10:55 AM
Views 277
23-10-2019, 06:59 AM
Last Post by reganlives
Views 451
12-09-2019, 02:13 PM
Last Post by IanH
Views 302
10-05-2019, 04:47 AM
Last Post by Fry-Up
Views 284
09-05-2019, 12:39 PM
Last Post by jasons
Views 657
10-07-2018, 03:13 AM
Last Post by Jimbob-T-Lex
Views 379
10-06-2018, 10:45 AM
Views 577
17-05-2018, 07:00 AM
Views 769
15-05-2018, 03:41 AM
