JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Manifold lambda
Manifold lambda
Manifold lambda
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:16 AM
What I've done is got hold of a stainless manifold and fitted then gone to put sensors back in and the rear one there is not enough room to get it in not without some major fabrication so I blanked it and wired the rear wiring so all comes off front sensor. Fine for a while then light came on if I unplug and reset codes with obd it shows all fine and sensors working fine but if I turn off and start again they dnt work! Anyone got any ideas what to do????
Jimbob-T-Lex
10-07-2018, 01:16 AM #1
10-07-2018, 01:18 AM
have you got a pic of the offending location
you should be able to get the sensor back in ?
what about fitting it then fitting the manifold ?
10-07-2018, 01:18 AM #2
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:29 AM
I tried all mate there is no room just hits the bulk head basically a badly designed manifold unless I get the sensor fixing moved or reshape my bulk head then Im gonna have to wire rear into the front just weird how it works but if I turn off and start her up again it stops and I get engine check light
Jimbob-T-Lex
10-07-2018, 01:29 AM #3
10-07-2018, 01:30 AM
something dont sound right as when i had my manifold i wired both sensors into one input and it worked fine it have you tried plugging into the other sensor location ?
I.e not in bank 2 but in bank 1 ?
10-07-2018, 01:30 AM #4
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:34 AM
What I've done is I've bank 1 sensor fitted and plugged in and works fine then I wired from bank 1 sensor into where the bank 2 sensor connects, do you know what the black wires are I could have them wrong way round as there is two
Jimbob-T-Lex
10-07-2018, 01:34 AM #5
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:41 AM
[Image: 004-8.jpg]
[Image: 005-6.jpg]
Jimbob-T-Lex
10-07-2018, 01:41 AM #6
[Image: 004-8.jpg]
[Image: 005-6.jpg]
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:44 AM
Just googled and the black cables are heaters do i need to connect them as no sensor is actually there
Jimbob-T-Lex
10-07-2018, 01:44 AM #7
10-07-2018, 01:50 AM
when i piggy back mine i connected all of the wires in....
10-07-2018, 01:50 AM #8
Jimbob-T-Lex
Moderator
1,674
10-07-2018, 01:54 AM
i just cant see where the problem is it should work
Jimbob-T-Lex
10-07-2018, 01:54 AM #9
10-07-2018, 01:55 AM
What is the fault code the ecu is showing ?
10-07-2018, 01:55 AM #10
Views 476
26-02-2020, 05:32 AM
Last Post by S
Views 342
05-07-2018, 12:16 PM
Last Post by Kerja
Views 446
29-05-2018, 10:12 AM
Views 577
17-05-2018, 07:00 AM
Last Post by Jimbob-T-Lex
Views 769
15-05-2018, 03:41 AM
Views 710
24-11-2016, 10:21 AM
Views 336
12-10-2016, 01:25 PM
Last Post by mikeyb2009
