JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS300 Auto Levelling Headlight Sensor
jasons
09-05-2019, 10:37 AM
Light is up on the dash telling me I have a problem with them..
I understand there are 2 on the car, anyone know where to find them, how easy they are to replace and lastly the cost?
Cheers,
J
jasons
09-05-2019, 10:37 AM #1
Cheers,
J
mattlaw
09-05-2019, 11:48 AM
They cost a small fortune lol and you'll have one on the NSF, it mounts in the wheel arch and has a little arm goin down to the lower suspension arm, the other is on the Nsr and is mounted on the subframe with a little arm going to the lower suspension arm again, if I were you I'd remove both of them, check to see if they move freely, and remove the cover on them, it's only 4 screws, inside youll see 3 gold springs, there should be no corrosion inside, if you find any corrosion replace that one
mattlaw
09-05-2019, 11:48 AM #2
jasons
09-05-2019, 12:39 PM
Cheers fella.
J
jasons
09-05-2019, 12:39 PM #3
Cheers fella.
J
Views 331
13-12-2023, 02:06 PM
Views 1,200
02-11-2022, 10:55 AM
Views 315
12-06-2021, 09:38 AM
Replies 128
Views 6,342
20-08-2020, 09:09 AM
Last Post by Fry-Up
Views 772
30-12-2019, 06:50 AM
Last Post by reco2k
Replies 29
Views 985
30-11-2019, 01:20 AM
Views 230
22-11-2019, 02:45 PM
Views 266
01-11-2019, 02:01 PM
Last Post by rigga
Views 718
31-10-2019, 03:29 AM
Last Post by mike_01
Views 287
23-10-2019, 06:59 AM
Last Post by reganlives
