JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Headlight Problem - Possible Wiring Fault
Jon
01-11-2019, 11:41 AM
To put you in the picture, I was sat watching TV last night and got up to get a drink. As I walked passed the living room window, I noticed it had snowed slightly - the reflection of someones headlight at the front of my drive got my attention. As I looked outside, it looked as though I had left MY headlights on, which would be fine, except I haven't used my car in over a week.
I grabbed my car keys, went outside and battled the 2 or 3mm of snow we had, and made my way to my car. First thing I noticed was the headlights were on, but no sidelights or rear lights. I started the car, which started fine, turned lights on and off which didn't help, so I opened the bonnet to fine a Relay chattering away. I quickly pulled the relay, lights went off, closed the bonnet, locked the car and went back inside where it was warm.
I don't know which relay I pulled, as it was dark, but after a quick look at the wiring diagrams, i think its the head lamp relay, which would make sense (although I am not 100% which relay I took out at the moment, I'll look at the weekend).
SO........... what I am after is has anyone else had this problem? I know it'll be an easy fix (I am a BMS engineer by trade, so wiring and relays etc is nothing to me). I just don't want to waste half a day searching for the issue, if someone can point me there in 10 seconds?
I'm thinking its possibly a faulty relay, or maybe damp getting in somewhere? I've had the car over 8 years and never had this problem, but I do get the battery going flat in winter if I don't use the car for around 2 weeks or more, so maybe its related?
Let me know what you guys think.
Jon
01-11-2019, 11:41 AM #1
01-11-2019, 11:49 AM
I'd almost guarantee water has got into the theft control unit under the dash.
You can either change the unit or bypass it, though this would stop them flashing if the alarm go off or the auto lights working.
01-11-2019, 11:49 AM #2
rigga
01-11-2019, 12:04 PM
There's been a few reports of headlights being unable to turn off recently.
rigga
01-11-2019, 12:04 PM #3
Jon
Which side is the theft control unit? And what would it stop flashing? I'm not fussed about the auto lights, I dont use them anyway
Jon
01-11-2019, 12:04 PM #4
Jon
01-11-2019, 12:09 PM
rigga There's been a few reports of headlights being unable to turn off recently.
I havent read anything on here, so I asked before searching
BUT after reading your post, i decided to search and found this
http://www.outlawjapclub.co.uk/forum/sho...headlights
sounds exactly like my problem, so thats Saturdays job sorted!
Jon
01-11-2019, 12:09 PM #5
01-11-2019, 12:28 PM
Mine did this at one point there is a connection under the scuttle panel which had got wet and caused the lights to come on.....
01-11-2019, 12:28 PM #6
rigga
01-11-2019, 02:01 PM
Jon I havent read anything on here, so I asked before searching
Been a few repoted on the Lexus owners site, seeing as you found info on here too its not a uncommon issue, water ingress seems to be the culprit.
rigga
01-11-2019, 02:01 PM #7
Views 329
13-12-2023, 02:06 PM
Views 303
01-11-2021, 11:52 AM
Views 309
12-06-2021, 09:38 AM
Views 165
25-12-2020, 10:57 AM
Views 515
16-09-2020, 01:57 AM
Last Post by danny1377
Views 167
01-08-2020, 04:06 AM
Last Post by Connor376
Views 227
10-06-2020, 05:52 AM
Views 319
04-01-2020, 11:29 AM
Last Post by Dinho
Views 390
10-09-2019, 11:55 AM
Last Post by ormi
