JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza I have a problem
I have a problem
I have a problem
Dinho
02-01-2020, 02:51 PM
Ive started to notice that when driving at higher speeds (motorway) that the engine seems to be louder than normal, and there is also a bit of vibration on the acceleration pedal. Overall its just not as smooth as it once was.
Does anyone have any idea what could be wrong?
Any help would be appreciated.
Dinho
02-01-2020, 02:51 PM #1
jj260z
02-01-2020, 06:57 PM
Shocks
Bushes
Balancing
Steering rack
**** road conditions
Shut tyres
The list is endless really
jj260z
02-01-2020, 06:57 PM #2
Shocks
Bushes
Balancing
Steering rack
Shut tyres
jj260z
02-01-2020, 06:58 PM
**** I sound like a kiwi
jj260z
02-01-2020, 06:58 PM #3
James S
02-01-2020, 11:59 PM
My car does the same, start with tracking and balancing. As they are pretty cheap. Then look at bigger stuff, like your wheel geo. Smile
James S
02-01-2020, 11:59 PM #4
Dinho
03-01-2020, 06:45 AM
****! Thanks guys i'll work my way down the list, but I did have it tracked around 6 months ago but I must admit ive noticed its gone slightly out again and I dont know how thats happened, maybe a deep pothole..?
Dinho
03-01-2020, 06:45 AM #5
03-01-2020, 10:23 AM
when was the last time the wheel bearings were replaced?
03-01-2020, 10:23 AM #6
Dinho
04-01-2020, 04:40 AM
I'll be honest I don't know bandido. Ive been driving the car nearly 2 years now though. Would any of whats mentioned make the engine sound louder though? Im quite concerned. luckily for me ive just had a small tax rebate so I should be able to fix the problem aslong as its not a £200+ problem!
Dinho
04-01-2020, 04:40 AM #7
04-01-2020, 04:47 AM
does it get worse when you turn left and right at speed, changing lanes on the motorway etc then get a bit quieter when driving straight? If yes, could be a bearing. If no, probably something else.
04-01-2020, 04:47 AM #8
04-01-2020, 05:19 AM
coilpack on its way out???
04-01-2020, 05:19 AM #9
Dinho
04-01-2020, 11:29 AM
No its the same regardless bandido, also the mpg needle has been reacting, bouncing around and if its correct im using more petrol than usual. I can normally get it to stay around 40mpg, but I was getting around 30 and below on my last drive.
Could be dino, i might to take it for a diagnostics.
But I will be getting it aligned again as it has been pulling to the left and steering wheel is just off to the right.
Think im going to change a few things just to give it some fresh life, oil, check plugs etc.
Dinho
04-01-2020, 11:29 AM #10
Views 207
25-12-2020, 10:57 AM
Views 697
16-09-2020, 01:57 AM
Last Post by danny1377
Views 288
10-06-2020, 05:52 AM
Views 344
01-11-2019, 02:01 PM
Last Post by rigga
Views 472
10-09-2019, 11:55 AM
Last Post by ormi
Views 425
20-07-2019, 10:04 AM
Last Post by pauls_is200
Views 569
24-11-2018, 04:03 AM
Views 578
30-10-2018, 07:15 AM
Views 463
15-10-2018, 06:19 AM
Views 412
06-02-2018, 04:05 AM
Last Post by ormi
