JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza is200 door card problem
23-11-2018, 02:11 PM
How the **** do you get the front drivers side door card off? I've done the passenger no problem, but the bit of plastic around the door handle feels like its been welded on. I can't remove it and it's pissing me off a treat.
23-11-2018, 02:11 PM #1
23-11-2018, 03:01 PM
It should be the same as the passanger door Koss,
Just pops off I thought granted not near the car at the moment but that's how I remeber it can you see anything that don't look right
23-11-2018, 03:01 PM #2
23-11-2018, 03:17 PM
First remove the screw in the middle.
Then a slim screwdriver above and below the handle to pop it off that.
23-11-2018, 03:17 PM #3
23-11-2018, 11:05 PM
I've removed everything as I did the passenger side, it appears some daft ***** has glued the handle surround in to place. Just thought I'd better check it was the same as the passenger side before I kick 10 shades of shite out of it. Thanks guys!
23-11-2018, 11:05 PM #4
23-11-2018, 11:41 PM
there is a how to on this when i did my mirror light mod
http://www.outlawjapclub.co.uk/forum/sho...php?t=2714
here it is
23-11-2018, 11:41 PM #5
here it is
24-11-2018, 04:03 AM
Thanks Jay. This is exactly the method I've used for the other door cards, the drivers side one is just not budging. Everything except the door handle surround is off, which is annoying.
24-11-2018, 04:03 AM #6
Views 331
13-12-2023, 02:06 PM
Views 470
09-11-2023, 03:46 AM
Last Post by Dinho
Views 702
06-11-2022, 01:49 AM
Views 1,200
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,168
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 461
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,724
04-08-2021, 04:34 AM
Last Post by cjoseph
