JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lexus IS200 Reprogramming Key Fob
Pages (4): 1 2 3 4 Next
Sam B
28-09-2016, 12:43 PM
My central locking has decided to play up, Ive seen topics about some IS200's forgetting the keys and owners having to reprogram them. Found a few step by step instructions but none seem to work.
any ideas? want to sort it ASAP as look a right prat having to lock the doors on the inside then get out and lock the drivers door lol! :Shooting:
[Image: DWSIG2.jpg]
Sam B
28-09-2016, 12:43 PM #1
[Image: DWSIG2.jpg]
28-09-2016, 10:38 PM
Here one example but can not say it works, as i not tried it
For 1998+ Toyota, Lexus
Add Duplicate Key
1. Simultaneously depress and release brake and accelerator pedals 1 time.
2. Insert existing master key into ignition.
3. Within 15 seconds depress and release accelerator pedal 5 times.
4. Within 20 seconds depress and release the brake pedal 6 times and
remove key.
5. Within 10 seconds insert new key into ignition.
6. Within 10 seconds depress and release the accelerator pedal 1 time.
7. After 80 seconds new key is registered and security light goes off.
8. Remove new key and depress and release brake pedal 1 time.
For 2002+ Toyota, Lexus
Add Duplicate Key
Requires one working Toyota/Lexus Master Key.
1. Make sure all doors and windows are closed.
2. Insert Master key into the ignition cylinder.
3. Cycle the ignition cylinder from On to OFF five times.
4. Open and close the “driver side” door 6 times.
5. Remove the Master Key and insert the new duplicates key.
6. TURN THE IGNITION CYLINDER ON.
7. The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
2ND VERSION SLIGHTLY DIFFERENT
To program the immobilizer bit of your new key:
First, have your new key cut. Then:
Add Duplicate Key
remove key.
To make your Lexus remember your key's wireless signal:
For the remote part in drivers seat WITH DOOR OPEN.
Start with door unlocked.
1. Put master key in ignition, turn to on, then back off and remove.
2. Using the lock/unlock button on drivers door. press lock.. then unlock 5 times.(lock,unlock,lock,unlock,lock,unlock,lock,un lock,lock,unlock)
3. Close drivers door, open drivers door.
4. Perform lock/unlock procedure again. DO NOT close and open drivers door. Just the lock/unlock procedure again.
5. Insert NEW key in to ignition and turn to on, then back off and remove.(at this point the doors should lock and unlock by themselves ONCE)
6. Now press both lock and unlock buttons on REMOTE. Release after about 1.5 seconds.
7. Now press just the lock button on remote.
once you press the lock button, the car should lock and unlock ONCE, if it lock unlocked TWICE you messed up somewhere.
8. Now open and close the drivers door a couple times to close programming.
if you did it right, remote will now work."
Good luck
28-09-2016, 10:38 PM #2
Add Duplicate Key
remove key.
Add Duplicate Key
Add Duplicate Key
remove key.
Good luck
29-09-2016, 02:58 AM
This is what worked for me on my 1999 model, slightly different from the last version above (with thanks to Stoney) :
1. Start with the driver's door open.
2. Insert a working Master Key (3 button) in to ignition, turn to on, then off and remove.
3. Lock, then unlock all the doors using the POWER LOCK button on the drivers door FIVE times (lock unlock lock unlock lock unlock lock unlock lock unlock)
4. Close drivers door, then re-open.
5. Lock, then unlock another FIVE times, exactly as before.
6. Insert your new key into the ignition and turn to on, then off again and remove.
7. The door locks will then start operating.
8. While they are clicking away,hold down the lock button on the new key and press the unlock button on the key 5 times. Then release and press unlock button once.
9. The doors will lock and unlock once...and you're done!
Edited 10-11-2009, 12:39 PM by steviewevie.
29-09-2016, 02:58 AM #3
29-09-2016, 03:03 AM
bit like the davinci code that
29-09-2016, 03:03 AM #4
Sam B
29-09-2016, 08:35 AM
cheers gents, Got it working just this second. well chuffed Smile this is the one that worked for me:
thanks for your help!
[Image: DWSIG2.jpg]
Sam B
29-09-2016, 08:35 AM #5
[Image: DWSIG2.jpg]
29-09-2016, 08:56 AM
Glad one of them worked Sam:thumbup1:
Just in case these work on different year cars what is your year car Sam?
29-09-2016, 08:56 AM #6
Sam B
29-09-2016, 01:23 PM
99' Smile
[Image: DWSIG2.jpg]
Sam B
29-09-2016, 01:23 PM #7
99' Smile
[Image: DWSIG2.jpg]
JeffMcC
03-01-2017, 06:30 AM
got a new key tried all but none worked. any 1 got any more
JeffMcC
03-01-2017, 06:30 AM #8
03-01-2017, 06:40 AM
just try it again.
you probably did something wrong.
try try and try again LOL
03-01-2017, 06:40 AM #9
just try it again.
04-01-2017, 04:31 AM
Jeff what year car did you try it on?
04-01-2017, 04:31 AM #10
Views 413
13-12-2023, 02:06 PM
Views 547
09-11-2023, 03:46 AM
Last Post by Dinho
Views 926
06-11-2022, 01:49 AM
Views 3,045
02-11-2022, 10:55 AM
Views 371
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,599
23-02-2022, 01:20 PM
Views 416
18-10-2021, 02:04 AM
Views 362
03-09-2021, 07:20 PM
Last Post by Ratchet
Views 577
03-09-2021, 11:04 AM
Views 535
29-08-2021, 09:59 AM
