JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Juddering problem
Juddering problem
Juddering problem
danny1377
18-08-2020, 11:31 PM
Right so as the title suggests I have this juddering fault.
it only happens every now and then and normally when I accelerate it really struggles to pull as if its not getting any power from one or more cylinders.
someone suggested putting some bg44k through it so I did that but it does not seem to have made any difference.
this all began after my car was stood up for a week or so.
any idea's folks as its driving me mad ?:Chair:
danny1377
18-08-2020, 11:31 PM #1
iceman
18-08-2020, 11:48 PM
most likely the duel mass as thay all judder abit as u set off from a standing start if ur not use to it u pick it as i did.if not then i would check all the air pipes as i had it when first got the car repalced the breather pipe on the under left side of the air box then checked the throttle body as it might be all gumed up with carbon under the buttfly valve.
iceman
18-08-2020, 11:48 PM #2
danny1377
19-08-2020, 12:23 AM
I don't think its the dual mass as it happens when im already driving along its when I put my foot down and its not every time.
danny1377
19-08-2020, 12:23 AM #3
19-08-2020, 08:28 AM
Clutch? Never had one go so I've no idea what it feels like.
19-08-2020, 08:28 AM #4
danny1377
19-08-2020, 08:55 AM
Could it be coil packs
If so any idea how to test em?
danny1377
19-08-2020, 08:55 AM #5
danny1377
19-08-2020, 11:52 PM
had a code reader on it this morning and no faults showing up at all
any ideas folks?
danny1377
19-08-2020, 11:52 PM #6
any ideas folks?
iceman
20-08-2020, 02:53 AM
easy way to test them is to start the car with the airbox off and the 10mm bolts off then just un plug one at a time if u un plug one and there's no sparking sound its gone. Ps if its working ital cut the engine. But saying that if it was a coil it should ping up the engine light.
Edited 01-10-2013, 12:39 PM by iceman.
iceman
20-08-2020, 02:53 AM #7
20-08-2020, 04:31 AM
you can get an electrical plug and then test them on the bench, thats what i do.
20-08-2020, 04:31 AM #8
danny1377
28-08-2020, 10:54 PM
Right so I have changed the spark plugs & air filter and cleaned the throttle body.
I also ran a tank of BG44K through it and I still have problems.
the juddering/ hesitation seems to be worse under load ie up hill or under acceleration .
any ideas as its driving me nuts?
danny1377
28-08-2020, 10:54 PM #9
iceman
28-08-2020, 11:48 PM
when u start it up in the morning or when cold is there a noises ?.
iceman
28-08-2020, 11:48 PM #10
Views 205
25-12-2020, 10:57 AM
Views 287
10-06-2020, 05:52 AM
Views 414
04-01-2020, 11:29 AM
Last Post by Dinho
Views 334
01-11-2019, 02:01 PM
Last Post by rigga
Views 471
10-09-2019, 11:55 AM
Last Post by ormi
Views 424
20-07-2019, 10:04 AM
Last Post by pauls_is200
Views 569
24-11-2018, 04:03 AM
Views 567
30-10-2018, 07:15 AM
Views 458
15-10-2018, 06:19 AM
Views 412
06-02-2018, 04:05 AM
Last Post by ormi
