JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza ok electrical problem .HELP
jameshunter
08-09-2020, 05:30 PM
Ok so i was driving up the motorway and the door open light starts flashing and wen i stopd the traction control light and the abs light starts flashing also the revs dropd to about 300rpm or less !!!
jameshunter
08-09-2020, 05:30 PM #1
mattlaw
08-09-2020, 05:45 PM
Any trouble codes coming up?
mattlaw
08-09-2020, 05:45 PM #2
jameshunter
08-09-2020, 05:46 PM
Not got an obd reader
jameshunter
08-09-2020, 05:46 PM #3
09-09-2020, 02:52 AM
Check the drivers side foot well fuse box mate, and see if your getting any water in there? sounds a bit like some of the problems related to water ingress to the fuse box?
09-09-2020, 02:52 AM #4
Chaos
09-09-2020, 05:45 AM
Might be worth checking the alternator as well, Lexus / Toyotas do all sorts of strange things with warning lights when the alternator's giving up.
HTH
Chaos
09-09-2020, 05:45 AM #5
HTH
jameshunter
09-09-2020, 07:27 AM
Chears guys i will be investigating today Smile
jameshunter
09-09-2020, 07:27 AM #6
jameshunter
09-09-2020, 04:48 PM
Removed kick panal at the fuze box and left the heatter on . fauld is now gone . probly just damp in thare
jameshunter
09-09-2020, 04:48 PM #7
09-09-2020, 05:44 PM
i would take the trim off and unplug all the connectors and check them you'll find some might be green spray contact cleaner on them then a wee bit of spray grease job done..
09-09-2020, 05:44 PM #8
Views 292
25-12-2021, 04:46 PM
Views 977
16-09-2021, 07:46 AM
Last Post by danny1377
Views 389
10-06-2021, 11:40 AM
Views 611
03-01-2021, 05:18 PM
Last Post by Dinho
Views 512
31-10-2020, 07:50 PM
Last Post by rigga
Views 534
19-07-2020, 03:53 PM
Last Post by pauls_is200
Views 610
24-01-2020, 12:53 PM
Last Post by is300_dino
Views 798
24-11-2019, 09:52 AM
Views 881
30-10-2019, 01:03 PM
Views 619
15-10-2019, 12:07 PM
