JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Light problem
Light problem
Light problem
reco2k
28-10-2018, 01:10 PM
Hi all,
Need some help, I went to change my numberplate bulbs for led ones and have found they are not working.. Also my front fog lights are not working either, I have checked both the tail fuse and the fr fog fuse and both are fine but still nothing, does anyone have any ideas as to what I can do?
Thanks
reco2k
28-10-2018, 01:10 PM #1
Hi all,
Thanks
28-10-2018, 01:17 PM
if they are LED are they in the right way round sorry its a daft question to ask but LED's due to there design will only work one way round unlike a filament Lamp
28-10-2018, 01:17 PM #2
reco2k
28-10-2018, 01:38 PM
tried with the original bulbs and still nothing to eliminate that
reco2k
28-10-2018, 01:38 PM #3
28-10-2018, 01:40 PM
ok do you know how to use a Multimeter ? if so could you try placing the leads from the multimeter in the pins of the Light fitting then turn the lights on this will tell you if you are getting any volts to the unit in question....
28-10-2018, 01:40 PM #4
28-10-2018, 01:43 PM
I would change the fuse just in case and try it again just to make sure its not the cheap little fuse
28-10-2018, 01:43 PM #5
reco2k
28-10-2018, 01:47 PM
Will check it with my multimeter on Sunday (day off) have changed both the fuses to make sure they weren't dodgy
reco2k
28-10-2018, 01:47 PM #6
reco2k
30-10-2018, 05:05 AM
Ok so I managed to get 1 part sorted, the numberplate lights started working after a fuse change and turning them round so that is one thing,
My fogs however are still not working, can hear the relay click when I turn them on, the fuse is all good but still nothing, unfortunately rain has stopped play so cannot check the bulbs and the voltage, is there any common faults with the fogs, bearing in mind the bumper has been off several times whilst fixing the front end damage
reco2k
30-10-2018, 05:05 AM #7
30-10-2018, 06:06 AM
it could be that the connections are scummed up from general wear and tear corrosion is enough to stop them working but can take time to show it self....
30-10-2018, 06:06 AM #8
reco2k
30-10-2018, 06:51 AM
Ok I will take them apart and clean them up and then check the voltages etc, thanks for the help guys
reco2k
30-10-2018, 06:51 AM #9
30-10-2018, 07:15 AM
not a problem mate thats what we are here for Big Grin
30-10-2018, 07:15 AM #10
Views 513
25-06-2021, 08:14 AM
Views 297
14-03-2021, 03:16 AM
Last Post by TezzaJoe
Views 544
14-01-2021, 04:38 AM
Last Post by lex2oos
Views 204
25-12-2020, 10:57 AM
Views 306
16-09-2020, 08:21 AM
Views 689
16-09-2020, 01:57 AM
Last Post by danny1377
Views 371
30-07-2020, 12:35 AM
Last Post by Dinho
Views 286
10-06-2020, 05:52 AM
Views 323
28-03-2020, 10:39 PM
Last Post by James S
Views 510
10-03-2020, 11:17 AM
