JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza My First IS200 Fault Any Help Please? Fuel Gauge Related
Barry
15-03-2020, 11:05 AM
Hi guys, i knew the day would eventually come and today my bay sprang a fault on me, can anyone shed some light on it please?
The battery was dead so i had to jump start it from my mates Astra, she turned over first time and everything was ok except i noticed this.
http://www.youtube.com/watch?v=3rSYwIE6SmM
I have half a tank of fuel yet its showing 0 (empty) and my fuel light was blinking constantly, i drove it for about 1/2 an hour and this was a constant issue.
Tried taking the ECU fuse out nothing, reset the car a few times and nothing.
:Sulk:
Barry
15-03-2020, 11:05 AM #1
:Sulk:
15-03-2020, 11:01 PM
Vauxhall contamination. Better wash car inside and out thoroughly.
15-03-2020, 11:01 PM #2
16-03-2020, 12:28 AM
I've seen this before but can't for the life of me remember what the solution was.
16-03-2020, 12:28 AM #3
16-03-2020, 12:42 AM
thats strange, mine reads 1/4 when its empty. started playing up when i changed my pump for a walbro. done all the resets like you and also had no joy rectifying it yet.
16-03-2020, 12:42 AM #4
Barry
16-03-2020, 08:25 AM
On doing some research with engine running i was advised to open the fuel flap, unscrew the fuel cover and then wiggle the white plastic internals of the fuel neck where you put the pump into when you fill up.
I did this opened the flap with my finger a few times, came back turned the car off for a minute, restarted it and all back to normal.
Fixed, so thanks for any input guys.
Barry
16-03-2020, 08:25 AM #5
16-03-2020, 08:27 AM
Stuck float then!
16-03-2020, 08:27 AM #6
Stuck float then!
Barry
16-03-2020, 09:15 AM
toxo Stuck float then!
Well its not done it ever before, and not since?
Would a stuck float not do this a lot and cause the gauge to over or under-read? Not drop to 0 and flash constantly?]
Im only asking by the way not preaching Smile
Barry
16-03-2020, 09:15 AM #7
16-03-2020, 10:36 AM
The Is200 tank has a hump in the middle so there's 2 floats. If one reads different to the other it causes a fault.
16-03-2020, 10:36 AM #8
Barry
16-03-2020, 10:17 PM
Sparkystav The Is200 tank has a hump in the middle so there's 2 floats. If one reads different to the other it causes a fault.
Good to know Stav thanks Smile
But why would this just randomly occur out of the blue and is it related to the jump start?
It's been fine ever since I did the fuel filler neck thing? I'm guessing the pressure released with engine running caused the float to dip and reset?
Barry
16-03-2020, 10:17 PM #9
18-03-2020, 07:25 AM
ive had this and as above opened the fuel tank and played with the float and it all sorted it self out
18-03-2020, 07:25 AM #10
Views 329
13-12-2023, 02:06 PM
Views 469
09-11-2023, 03:46 AM
Last Post by Dinho
Views 696
06-11-2022, 01:49 AM
Views 1,169
02-11-2022, 10:55 AM
Views 305
06-08-2022, 11:58 AM
Last Post by Brad92
Replies 38
Views 1,137
23-02-2022, 01:20 PM
Views 352
18-10-2021, 02:04 AM
Views 457
03-09-2021, 11:04 AM
Views 488
29-08-2021, 09:59 AM
Replies 35
Views 7,711
04-08-2021, 04:34 AM
Last Post by cjoseph
