JapCarForum Car Manufacturers Lexus/Toyota just a quick question will most the gs300 mk1 parts swap on to mk1 toyota aristo
350zdan
31-05-2020, 11:20 AM
just a quick question will most the gs300 mk1 parts swap on to my mk1 toyota aristo and also does any one no of any metal polishers that are any good at polishing car parts ? any help would be really appreciated thanks Smile
350zdan
31-05-2020, 11:20 AM #1
TurboPete
31-05-2020, 11:25 AM
Trusty old Autosol is good for polishing metal parts and it's available in about all car shops. Used on some fine wire wool works really well then you can go over it again just using a microfibre cloth.
If you want something a bit different try these:
http://www.polishedbliss.co.uk/acatalog/...lants.html
Hope that helps.
TurboPete
31-05-2020, 11:25 AM #2
Hope that helps.
350zdan
01-06-2020, 07:15 AM
TurboPete Trusty old Autosol is good for polishing metal parts and it's available in about all car shops. Used on some fine wire wool works really well then you can go over it again just using a microfibre cloth.
Hope that helps.
hi thanks pete i will look in to it Smile also thinking of chroming or getting the cam covers polished do you no any where that does that sort of work and want a few bits doing ??
350zdan
01-06-2020, 07:15 AM #3
Hope that helps.
Views 447
18-03-2022, 07:20 AM
Last Post by bounty`
Views 254
11-11-2021, 08:45 PM
Views 563
21-10-2020, 05:28 PM
Last Post by Chaos
Views 1,189
14-07-2020, 05:20 PM
Last Post by old school
Views 881
08-06-2020, 09:43 AM
Last Post by 350zdan
Views 854
29-05-2020, 09:21 PM
Views 479
10-11-2019, 05:40 PM
Last Post by mzr
Views 1,500
16-10-2019, 03:33 PM
Last Post by Tango
