JapCarForum Car Manufacturers Lexus/Toyota mk1 toyota aristo delimiter kit
350zdan
08-06-2019, 04:08 AM
does any one know where to get a delimiter removed and what i need to buy to do the job as my 1993 toyota aristo is restricted to 112mph so would like to remove the limiter i have looked around the net but still no luck any info would be much appreciated Smile
350zdan
08-06-2019, 04:08 AM #1
08-06-2019, 07:25 AM
Does the vehicle use a speedo cable or an electronic sender?
08-06-2019, 07:25 AM #2
350zdan
08-06-2019, 07:35 AM
hi as far as i no there electric sender Smile
350zdan
08-06-2019, 07:35 AM #3
08-06-2019, 07:37 AM
Has it been converted from KPH to MPH, or did it have both scales on the speedo?
08-06-2019, 07:37 AM #4
350zdan
08-06-2019, 07:57 AM
its got both mph and kmh on the speedo just that i cant go over 112mph
350zdan
08-06-2019, 07:57 AM #5
08-06-2019, 12:12 PM
i'm confused you want the de-limiter removed?
08-06-2019, 12:12 PM #6
350zdan
09-06-2019, 03:49 AM
Dan_Turism0 i'm confused you want the de-limiter removed?
no i want the limiter removed as can only go 112mph the car wont go any faster with the de-limiter it will go faster Smile
350zdan
09-06-2019, 03:49 AM #7
350zdan
09-06-2019, 03:54 AM
i want the limiter removed as can only go 112mph the car wont go any faster with the de-limiter kit it will go faster then 112 mph
350zdan
09-06-2019, 03:54 AM #8
Views 175
11-11-2020, 02:56 PM
Views 298
22-10-2019, 11:39 AM
Last Post by Chaos
Views 730
15-07-2019, 11:31 AM
Last Post by old school
Views 571
08-05-2017, 09:03 AM
Last Post by Chri5
Views 631
14-04-2017, 03:10 AM
