JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications wiring black box
wiring black box
wiring black box
JayJay1374
04-09-2019, 04:51 AM
alright guys, i recieved my blackbox from patrick today, just wondering if anyone has a picture of how its wired?
cheers
JJ
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
04-09-2019, 04:51 AM #1
cheers
JJ
04-09-2019, 05:04 AM
There's a picture here for the FCD, might be of use?
[Image: fcdwiringonmyLex.jpg]
http://www.outlawjapclub.co.uk/forum/sho...php?t=7138
04-09-2019, 05:04 AM #2
JayJay1374
04-09-2019, 05:12 AM
well ive tried wiring it like this:
[Image: 91A842A2-6E1B-4244-BF7F-95C0F5F68874-475...6C9B01.jpg]
and it ran like a bag of spanners and got fuel cut at 3.5k
i also tried it with the yellow and green swapped round, went for a drive it was fine until i planted my foot and i got fuel cut again! help!!!!
Edited 15-10-2012, 02:47 PM by JayJay1374.
JayJay1374
04-09-2019, 05:12 AM #3
P.Lindblom
04-09-2019, 05:47 AM
Sorry mate. I ususally include instructions in the packages, but this time I apparently forgot to do that. I've just e-mailed you the instructions.
In the picture above the green and yellow wires from the Black box are connected the wrong way. The green BB wire should go into the ECU and the green BB wire should go away from the ECU.
Unfortunately, by connecting it the wrong way the Black box might have got damaged. For my next batch of Black boxes I've added a diode to prevent any damage if the they are connected the wrong way round.
If your Black box is damaged there is probably only one component that needs to be replaced and it's easily done if you know how to solder. If not you can send it back to me and I'll replace the component for you. If so, I'll add the diode as well.
Let me know if you can't make it run properly and I'll explain how you can troubleshoot the components in the Black box.
Edited 15-10-2012, 03:26 PM by P.Lindblom.
P.Lindblom
04-09-2019, 05:47 AM #4
jomo
04-09-2019, 06:13 AM
^^^^^^^^^ Man genius^^^^^^^^^^^^
jomo
04-09-2019, 06:13 AM #5
JayJay1374
04-09-2019, 07:28 AM
All sorted. Luckily no damage has been caused. Bye bye fuel cut Smile
JayJay1374
04-09-2019, 07:28 AM #6
Jon
05-09-2019, 10:59 AM
Patrick, any chance of making a guide/how to for the Diode fix? Mine is wired up correctly, but i'll add the diode as a safety precaution
By the way, I think ive had the black box from you nearly 10 months and its been perfect, thanks mate!
Jon
05-09-2019, 10:59 AM #7
JayJay1374
11-09-2019, 03:54 AM
well im still getting fuel cut when the cars cold! this is a mystery!
JayJay1374
11-09-2019, 03:54 AM #8
Bazil75
24-05-2023, 05:16 AM
what color wire does the black cable from the blackbox go to? is it white/back or blue/red I cannot tell in the picture
Bazil75
24-05-2023, 05:16 AM #9
24-05-2023, 05:34 AM
Bazil75 what color wire does the black cable from the blackbox go to? is it white/back or blue/red I cannot tell in the picture
White/Black.
White/blacks are almost always earths on the lexus
24-05-2023, 05:34 AM #10
White/Black.
Views 436
19-01-2023, 11:42 AM
Views 416
26-03-2021, 10:59 AM
Views 740
24-04-2020, 08:19 AM
Last Post by buzzard2011
Views 376
03-10-2019, 11:45 AM
Last Post by JayJay1374
Views 410
11-07-2019, 01:51 PM
Views 351
14-06-2019, 04:20 AM
Views 507
12-07-2016, 09:44 AM
