HID installation problem
Guys,
I've plugged my HID in and it doesn't do a thing. As far as I can see its pretty much plug and play. There are 2 unused connectors which I believe are for use if you have purchased the HIgh/Low beam kit, which I haven't.
This is the kit I've bought. http://www.ebay.co.uk/itm/300532299986?s...1439.l2648
Has anyone else used it? Can anyone think what the issue could be?
Thanks,
John
You shouldn't have any left over connections. You plug the standard power plug (that went on your original bulb) into the connector on the ballast, then the other connectors (that have the box inline) fit to the connectors on the bulb. If they don't light, reverse one of the plugs from the bulb (as in, turn it 180 degrees and plug it back in)
As above try flipping the plug round (even if it won't fit, you might need to force it a bit) - common problem is that they're wired the wrong way round.
That's seriously fcuked up! Yep, I reversed the connector and its working.
I did think of trying that but I was too scared of blowing something on 'wishful thinking' solution.
Thanks for that fellas Reps and much appreciation
Now to finish off the Angel.... What a drag that is.
Cheers,
John
Well I,finally got the HID lights and Angel Eyes installed today. It too me a day and a half to do it! Largely due to the fact I have a gas oven and I was concerned about the size of the light fitting inside, without touching the flame. This meant I had to use a heat. Gun, which took forever!
I think the end result is looks fantastic.
Sadly I have made one bulls up! I don't blame anyone here, as it was entirely my own stupid fault, but I remembered reading somewhere that Braso is,good,for,cleaning headlights. I tried it on the first light but stupidly cleaned the inside of the lens. This left white marks on the clear reflective part. I'll need to take it back out at some point and replace the lens
Aside,from that one error, I'm happy.
I also did a full service, including a gearbox oil change.
Thanks for the earlier advice. I'm still amazed they send them HID cables out like that.
Chasers,
John
I get the feeling with HID's that lexus may just be backwards as nearly all of us have to turn them around lol
Like Stav said, Toyota/Lexus seem to just do everything opposite to normal.
My HIDs are wired 'backwards', as were my LED foglights when I had them.
sprinter2012 Like Stav said, Toyota/Lexus seem to just do everything opposite to normal.
Mine is the same, had to turn plug round on hid's.
Had me stumped for couple of days though lol
wullie_trd Mine is the same, had to turn plug round on hid's.
