JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Need help with Toad alarm installation
ZAIS200
20-03-2020, 01:02 AM
Hi All,
I was able to acquire a well preserved Toad (C2 - I believe) alarm complete with remote from a mate of mine for free i would like to install this into my 2000 IS200, but i need to know which wires i need to look for can any one help me with either a wiring diagram or a clue as to where i can find the correct wires and the colours of these wires to which i can connect the alarm wires too?
Thanks in advance guys...
ZAIS200
20-03-2020, 01:02 AM #1
Hi All,
20-03-2020, 01:22 AM
I've got the diagram for an Ai606, you could cross your fingers that the wires are the same colours...
Edit: Wait, you meant the wires in the car didn't you. Either Rabster or Stav is your man in this case!
Edited 01-05-2013, 11:16 AM by toxo.
20-03-2020, 01:22 AM #2
ZAIS200
20-03-2020, 01:42 AM
Thanks Toxo, but yeah its on the car side that i need the help
ZAIS200
20-03-2020, 01:42 AM #3
20-03-2020, 03:23 AM
I did help jimbob last year somewhere in his build thread it has the wires for the central locking and what you have to do
Hope that helps I will try and locate my list of wires tonight
20-03-2020, 03:23 AM #4
ZAIS200
20-03-2020, 03:40 AM
Cheers thanks any help would be apreciated
ZAIS200
20-03-2020, 03:40 AM #5
22-03-2020, 07:14 AM
Alarm Info
12V|white & white/red |+ |ignition harness |
STARTER|black/white |+ |ignition harness |
IGNITION|black/red |+ |ignition harness |
SECOND IGNITION|blue/red |+ |ignition harness |
ACCESSORY|red |+ |ignition harness |
LOCK MOTOR|green/yellow | |body ECU *1 |
UNLOCK MOTOR|blue/black | |body ECU *1 |
DISARM DEFEAT|red/white | |body ECU *1 |
PARKING LIGHTS +|green | |drivers kick panel |
PARKING LIGHTS -|red | |headlight switch |
HEADLIGHTS|red/blue |- |headlight switch |
DOOR TRIGGER|*3 |- |body ECU *1 |
DOME SUPERVISION|use door trigger | | |
TRUNK/HATCH PIN|red/yellow |- |drivers kick panel |
HOOD PIN|blue |- |alarm module *4 |
TRNK/HTCH RELEASE|blue/white |5wi|body ECU *1 |
DISARM NO UNLOCK|black/yellow *7 |- |steering column |
TACHOMETER|black | |igniter *2 |
SPEED SENSE|red/yellow | |abs and traction ECU *5 |
BRAKE WIRE|green/white | + |brake pedal switch |
HORN TRIGGER|green/white |- |steering column |
WIPERS|blu/blk(L),blu/red(H) |+ |steering column |
1 The body ECU is attach to the top of the fusebox.
2 The igniter is on the driver side strut tower.
3 The driver door trigger is red/green, front passenger door is red/black, rear doors is red/white.
4 The alarm module is above the drivers kick panel.
5 The ABS and traction ECU is above the drivers kick panel.
6 The amplifier is above the passenger kick panel. The left rear woofer wires are black/white - yellow/red. The right rear woofer wires are red/white - white/blue.
7 This is the ignition key sense wire. Using the status output wire from the remote start to ground this wire will disarm the alarm without unlocking the doors.
22-03-2020, 07:14 AM #6
Alarm Info
ZAIS200
22-03-2020, 11:47 PM
Cheers Rabster, thanks for this, lets see how i get on:whistling:
ZAIS200
22-03-2020, 11:47 PM #7
ZAIS200
08-04-2020, 01:17 AM
I had a root around this weekend trying to figure this lot out and i couldn't make any sense of it, either i was looking at the wrong wires or the colour coding was different...
I think i'm gonna try sell on this Toad and use what ever i can make off it having a newer system installed professionally, sorry i wasted your time Rabster, i still appreciated the assist though unless i can get some visual aid i'm to worried i'm gonna mess up my cars wirring and get this all wrong...
ZAIS200
08-04-2020, 01:17 AM #8
10-07-2020, 04:10 AM
can you get some pictures of the module up ?
10-07-2020, 04:10 AM #9
ZAIS200
10-07-2020, 04:21 AM
Yip answering you in my previous thread...
ZAIS200
10-07-2020, 04:21 AM #10
Views 1,182
22-05-2022, 12:25 PM
Views 680
20-05-2022, 02:02 AM
Last Post by reganlives
Views 664
30-03-2021, 03:12 AM
Last Post by Millo73
Views 1,031
21-09-2019, 12:23 PM
Views 524
28-03-2019, 10:00 AM
Views 1,047
06-12-2018, 01:26 PM
Views 780
11-04-2018, 12:56 AM
Views 1,234
06-04-2018, 02:11 AM
Last Post by jimxms
Views 6,525
31-12-2017, 12:08 AM
Last Post by jimxms
Replies 27
Views 2,569
05-09-2016, 10:25 PM
