JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications SC Induction Pipework
JayJay1374
15-09-2019, 01:44 AM
Has anyone got pictures of their supercharger with an induction kit fitted?
for the pipework in guessing you need a 180 bend off the charger, a 45 bend and some straight pipe?
cheers
JJ
http://www.facebook.com/Sxe10CrewUk
Stickers available!!!, PM me.
JayJay1374
15-09-2019, 01:44 AM #1
cheers
JJ
15-09-2019, 02:30 AM
You can have a look at my project thread, i have a couple of pictures
15-09-2019, 02:30 AM #2
15-09-2019, 09:20 AM
Bandit made a list of the parts needed i think for a induction on a SC will see if i can find it
15-09-2019, 09:20 AM #3
15-09-2019, 09:57 AM
This was the one i made for mine, and just added a small breather filter to the rocker breather pipe, could always link it to the pipe though with a t-piece?
Used a 63mm 180 degree silicone bend and a silicone step up for the Apexi air filter, and a chrome 60mm table leg from B&Q, as it worked out a lot cheaper than buying a length of stainless :tongue_smilie:
[Image: DSCF1566.jpg]
Can just see the breather filter on this pic,
[Image: lexenginebay2ndOct2010.jpg]
Edited 26-10-2012, 07:34 PM by Bandit.
15-09-2019, 09:57 AM #4
JayJay1374
16-09-2019, 08:31 AM
spot on mate just what i needed! Smile
JayJay1374
16-09-2019, 08:31 AM #5
16-09-2019, 09:38 AM
i knew it was somewhere lol
16-09-2019, 09:38 AM #6
JayJay1374
18-09-2019, 06:14 AM
so where do you mount the airflow sensor?
JayJay1374
18-09-2019, 06:14 AM #7
18-09-2019, 07:46 AM
JayJay1374 so where do you mount the airflow sensor?
Airflow sensor? You mean that little black sensor that used to be in the OEM airbox? That's actually inlet air temperature, and ideally needs to be close to the throttle body to give an accurate measurement, but tbh it makes naff all difference. Smile
18-09-2019, 07:46 AM #8
18-09-2019, 09:26 AM
sprinter2012 Airflow sensor? You mean that little black sensor that used to be in the OEM airbox? That's actually inlet air temperature, and ideally needs to be close to the throttle body to give an accurate measurement, but tbh it makes naff all difference. Smile
I had mine fitted next to the air filter.
18-09-2019, 09:26 AM #9
18-09-2019, 10:15 AM
Had mine pushed into the bottom of the silicone T piece, where the blow off valve is on the pic's above, just make sure you seal the fitting so it doesn't leak pressure! shouldn't have to extend the original wiring that way either?
18-09-2019, 10:15 AM #10
Replies 32
Views 1,994
22-01-2017, 02:23 PM
Last Post by koka
